what interiors fit..
im tryin to re-do my interior on my 73 c10. just was tryin to figure out what interiors would actually fit without me cuttin or making brackets for stuff. if ya have any pictures , websites or info it would be helpful!!
Re: what interiors fit..
Other than the door panels and seatbelts, everything should swap out, I'm pretty sure, from 73-80.
here is a picture of mine. ive seen some that cover the whole door. jus curious of what these guys made them of and if i can install some trailblazer,jimmy,s 10 panels. far as my bench seat goes, i would like to replace it with some buckets without drilling any holes in the floor of it. i notice the gas tank would be in the way if i installed anyway. any ideas, pictures, or fabricators who have done this would be helpful info. thanks a mill
Those are 77 and up doors. So, you can either use 77-80 panels as a direct bolt in, or use 81-87 panels if you swap the interior door handles/cups too.
It'd be alot cooler if you did
Nobody on here that I know of is running Trailblazer, Jimmy, or S10 door panels. They would not be close to the same, and all would require some sort of modification and maybe even fiberglass work. As for the seats, unless you make some brackets for the seats you want to use, nothing is a direct swap.
'88 seats will fit if you take the risers off the bottom. No bracket fab necessary. I put the original sliders on the '88 seat. Only had to drill a few extra holes, most of the original holes lined up. Had to make a few minor "adjustments"
with a 4lb hammer, but overall it wasn't too tough. I re-dyed my door panels, and put a $99 dollar cover on the dash. For a few hundred bucks, my interior looks almost good as new. Pics below. http://67-72chevytrucks.com/vboard/s...d.php?t=306974 Last edited by Richard D; 10-13-2008 at 12:01 PM. |
hey Richard D where did ya get the cover for your dash? i thought of tryint to fiberglass the dash myself cant be too hard jus some time thats all.
#9 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
http://store.73-87chevytrucks.com/me...tegory_Code=DC
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
6.0 powered square
heres the full cover door panels you might be thinking of,
http://store.73-87chevytrucks.com/me...tegory_Code=DP here is a article on interior http://www.73-87.com/7387garage/inte...or_install.htm
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
I got mine from LMC Truck, a Dashtop. It's USA made and reallly nice.
http://www.lmctruck.com/ICATALOG/CC/full.aspx?Page=104 Hey Capt., what brand cover do you sell? I may be needing another in the future. |
I normally sell Coverlay, but I can get Dashtop also.
What is your opinion between the two?
I personally like Coverlay which is why I list them. I normally stick with a product I like.
