Old 10-12-2008, 02:03 AM   #1
abadsvt
abadsvt's Avatar
Is a vented cap enough?
Hi guys! I was doing some research on a different way to vent my gas tank. I know that normally people just coil up some tubing as there vent but I was hoping for something less bulky. I read that some people just use a vented cap which i am using but is it enough? I thought about installing a one way check valve allowing air to come into the tank and use the vented cap to allow air to go out of the tank but thought i would see what others thought. The gas cap vent is just a really small pinhole probably 1/16 big. I was worried it wouldn't be big enough hole to let the hot air/fumes out. It has been a long day and my brain hurts so any comments would be appreciated. Thanks
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 10-12-2008, 07:47 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Is a vented cap enough?
Not to sound like a smart a$$ but vented caps worked on these trucks for 40 or so years. Unless you have a monster gas sucking race motor i think the vented cap will work just fine....
LockDoc
Leon
Old 10-12-2008, 12:00 PM   #3
abadsvt
abadsvt's Avatar
LockDoc
No worries! The reason i am asking is because i am not using anything stock. It is all custom built and aftermarket parts. I just wanted to double check.
(Project truck)
