tips for stopping a fuel leak?
I changed the fuel filter and wouldnt you know it, I now have a tiny leak coming from the line at the carb.. And unless I do something, I really dont think I'm going to get ti to seal without getting anew line ad/or fitting.
ANy ideas? are lines easy to find? suppose I could use a flange tool and clean it up? ANy kind of sealer I could try? My preference would be to find a line, fitting, and filter housing all new.. are these parts readily availabe? Thanks
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 ![]() 2001.5 VW Passat beater 1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint ![]() |
Between Trucks...
Re: tips for stopping a fuel leak?
Is it a hardline? If it is try some teflon tape.
Beat it to fit, Paint it to match... ![]() |
use a sealer called "indian head" it seals anything
you can get it at advance auto
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
if its a filter that is external to the 4barrel Qjet carb it's an aftermarket part and local parts stores have fuel filters and steel gas lines
its all about the +6 inches
if it is the stock filter housing on the carb, the kind with a flaired line, then you can't add anything to the threads to seal it.
Try opening it back up, and check the sealing surface for crap. Clean it, and reassemble. |
#6 | |
yeah, did all that, which is why i was thinking I need a new line.. will lmc have a line? I know I could bend a new one and flange it, but if I could get an oem one cheap, I'd rather go that route.
go to napa and ask for 3/8 brake line. Measure how much you need to go from the carb inlest to where ever you need to go (pump, or additional filter)
Plan on getting 2 if you are not good at bending lines. |
![]() Join Date: Sep 2005
please it is a flare fitting adding any kind of sealer will cause it to leak
