Old 10-12-2008, 11:50 PM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
how low does my truck look
I realy don't under stand,I lowerd my truck back in march and I orderd djm 3inch drop spindles 2inch djm drop coils and a beltec flip kit from summit but the front only looks like, its only been lowerd 3 1/2 to 4 inchs so i'm thinking the springs are heavy duty srings and the stance is really buging me, so how much lower would have to go to have the top of the rim to wheel well be the same front and back.
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-13-2008, 08:17 AM   #2
slug
slug's Avatar
Re: how low does my truck look
well, heres the thing. the front and rear wheel well opening are different heights. if you want them to be at the same height your going to have a slight rake.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 10-13-2008, 08:38 AM   #3
flamingbig10
6.0 powered square
that what I want
Aaron
Old 10-13-2008, 08:58 AM   #4
grinch4om
dang its hot
grinch4om's Avatar
check your clearances and be aware of your topography and if you can go lower, start with half a coil on the front,
grinch4om is offline   Reply With Quote
Old 10-13-2008, 10:38 PM   #5
Square84
I don't think these pills work
Square84's Avatar
mine is a 4/6 and it sits like that the back tires tuck but the front there is about a 1 inch gap. but if you measure or stand back and look the front is actually lower, but my tires are smaller on the front than the back.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 10-14-2008, 01:24 AM   #6
ocbaud
Garage Queen Material
mines the same way with 4.5" drop in the front and a rear flip kit.
i hate it, the front looks so much higher.
but...
if you step back 20+ feet, it looks perfect
ocbaud is offline   Reply With Quote
Old 10-14-2008, 02:15 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Start cutting the coils. 1/2 coil = approximately 1 inch of drop.
Keith
Convert to disc brakes.
Old 10-14-2008, 02:42 PM   #8
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I'm guessing in the neighborhood of 2 1/2". Measure the vertical distance between the rim and the fender lip on the front and rear for a more accurate calculation. You'll 'bably end up with at least a 2" rake. It may be challenging to accomplish this by cutting enough coils off of a drop coil without causing alignment, clearance and ride issues. It may be Dropmember time.
Sumin' like this:
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 10-14-2008, 06:51 PM   #9
slugish
Slugish
Question Re: how low does my truck look
Yea ,I see what you mean . according to your specs you should be 5 in. in the front & approx 6 in the rear - Iagree the rear looks perfect (in my old fart opionion) My 84 is 5.5 in in front (2.5 spindles & 3 in drop coils from Eibach)Sorry dont have pic. but mine tucks very well , & yours should to// theres only 1/2 in difference in yours & mine . Are The coils seated into the pockets well -- Im sure they are , but your truck should be lower than that in front with a 5 in drop. ????
slugish is offline   Reply With Quote
Old 10-14-2008, 09:01 PM   #10
SCOTI
SCOTI's Avatar
It looks like a 4/6 drop from the pics. What size are your F/R tires? Mine has 3" spindles + 1-coil cut & a flip-kit + shackles . .....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-14-2008, 08:41 PM   #11
flamingbig10
6.0 powered square
thanks for the info everyone and thanks for the photo shop boxrods
in the future I might bag it, but fo now I'll cut a coil off
Aaron
Old 10-14-2008, 08:43 PM   #12
flamingbig10
6.0 powered square
here is what my truck looked with 2'' drop shackles
Aaron
Old 10-14-2008, 09:27 PM   #13
flamingbig10
6.0 powered square
front 215-70 26.9
back 275-60 28
Aaron
Old 10-14-2008, 09:34 PM   #14
SCOTI
SCOTI's Avatar
Originally Posted by flamingbig10 View Post
front 215-70 26.9
back 275-60 28
My tires are a little taller 215-75-15's. Check these measurements against your truck.
Front.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2008, 09:38 PM   #15
SCOTI
SCOTI's Avatar
Rear w/255-70-15's.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2008, 09:44 PM   #16
flamingbig10
6.0 powered square
mines 26 1/2 from were yours is 25 5/16
and the rear is 25
Aaron
Old 10-14-2008, 09:52 PM   #17
flamingbig10
6.0 powered square
here the back of mine
here is when I had the drop shackle
Aaron
Old 10-14-2008, 10:24 PM   #18
lolife99
lolife99's Avatar
flamingbig10,... another coil removed, is going to drop it 2 inches more. Correct alignment will not be easy,... if at all possible.
Keith
Old 10-14-2008, 11:28 PM   #19
flamingbig10
6.0 powered square
oops I ment a half a coil
Aaron
