![]() Join Date: Oct 2007
It seems that everyone cuts them up
I have a 402ci in my 72 and need the powersteering hoses to hook up to my big block pump from the box.
But, every plave I inquire about the hoses ,,they say they cut them up rather than take them off when parting out the truck. You cannot find them in wrecking yards so was wondering are there other hoses from other vehicle that has the same bends as the big block trucks that I can substitute ?.. papa from close to Portland Oregon |
![]() Join Date: Aug 2004
Re: It seems that everyone cuts them up
The high pressure hose was still available from the chain parts stores last time I checked @ Oreilly's or Advance.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
I used a hose from a 73 with a 454 and it worked great. I ordered it from Advanced here in Florida. See if that is what you are looking for.
Dale |
Moderator
![]() Join Date: May 2007
I have been unsuccessful trying to find a hi pressure hose from a parts house. Your best bet would be to take an old one to a hose shop and have them make a duplicate. Advance showed me 2 hoses they had listed for the big block trucks, and both of them weere incorrect.
![]() Join Date: Mar 2003
If I remember correctly, Wes had a bunch made up a while ago and had them for sale
#7 | |
Appreciate help on who Wes is and how I can get hold of him.. I tried bending a couple that had the same ends but the bend I need to clear the pulley and stay clear of belts is jsut a bit sharp.. thx by the way ,,papa |
#8 | |
Sierra Grande Club
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#9 | |
Thats what I have been wanting to do ,,but don't have one to rehose. and need one with the hose still intact so to get the correct lenghth.. thx good idea we have ,but still need the original,, papa |
Moderator
Frank also had some for sale (pickmup is his name on this board)
I dont have a big block but I just went thru this issue with the hoses so I had some made locally for $45.00 for both perfect fit and problem solved....I got tired of buying the so called correct ones and then not fitting..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
I got this information from the NAPA prolink web site.
Pressure hose Part#NPS 71531 Return hose Part#NPS 71201 Hope this helps |
The stuff they sell in the parts store is get by stuff, they are not correct for the application. The correct hose is difficult to locate. When I built my 71, I was able to locate one in Texas through parts voice (GM program) . Pickumup is the only one that I have seen with the correct repop of the hose, but he was only going to have a limited supply. If he does not have any more try contacting Uncle in Georgia, he has several bb trucks and may have a hose for sale.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle Last edited by 71 super; 10-13-2008 at 09:37 PM. |
