ring gear
Does any body know what the torque specs. are on the ring gear bolts for a 12 bolt eaton posi diff.?
Also what are the torque specs for the carriers bearing cap?
1969 red k/10 with sb350 4.11 gear ratio, front disk, 3 speed automatic |
Re: ring gear
Thank you! that helps alot.
Where can i buy this manual?
Re: ring gear
Are you using a 1 ton axle in your K-10?
The torque specs listed are for a 1 ton axle. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: ring gear
the overhauk manuals are available as reprints from most vendors on the site or are common on ebay price is around $25plus shipping about the best money you can spend on your truck
Re: ring gear
no its for a half ton
Re: ring gear
The torque specifications for the 1/2 ton ring gear bolts is 50 lb./ft.
The torque specification for bearing cap bolts is 55 lb./ft. Jim
Re: ring gear
thank you
