Georgia Boy
I'm considering changing to a bigger swaybar in the front and adding one in the back. What bars did ya'll buy and what size? Did you see a noticable difference in handling? I'm probably going to lower my truck at least 2"/4", so would adding a rear sway bar be a problem with a drop?
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi. |
Re: Sway bars!
I've got the heavy duty C-20 factory bar on the front, and a Belltech bar on the rear. Truck is lowered with 3" drop control arms and a flip kit. It still feels a little soft cornering to me. I am sure the big block with 22 year old small block coil springs and worn out shocks up front is not helping. And I have the light duty spring pack in the rear.
- Greg |
It followed me home?
Re: Sway bars!
I added a rear bar on my '85 and it was a night and day difference, I'll be adding one to my blazer soon too.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Right turn Clyde
Re: Sway bars!
Got any pictures of the rear sway bar setup. I havent seen very many at all on these trucks.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
great southern land
Re: Sway bars!
hmm interesting, i have the front sway bar, but i too would like to see how rear bars are put in.
rod ![]() 86 chevy c10 silverado |
dang its hot
Re: Sway bars!
like 454HO my engine and mods are the same. I used a front sway bar off a 3/4 ton suburban it was night and day difference. I have been thinking of another pair of shocks on the front and a rear bar although withe back light as they are I am concerned of to much roll stiffness in the rear and causing the inside tire to lift in corners, anyone experienced this?
#7 | |
Re: Sway bars!
#8 | |
Right turn Clyde
Re: Sway bars!
I would think it would affect a stock or lifted truck more than a lowered truck.
Parts and more parts
Re: Sway bars!
I am running Hellwig heavy duty bars on my 84. I upgraded many years ago and now I can corner far better than most trucks. Deinite difference adding the back bar to the mix.
Re: Sway bars!
Here's pics of my sway bars -
The rear is a Belltech 1-1/8" bar The front is a factory 1-1/4" bar from a 3/4 ton truck
- Greg |
It'd be alot cooler if you did
Re: Sway bars!
I tried starting a thread on this here, but did not get much response.
http://67-72chevytrucks.com/vboard/s...d.php?t=310081 |
Re: Sway bars!
This subject does seem to come up pretty often. Maybe this should turn into a FAQ thread...
- Greg |
Re: Sway bars!
yeah,that's a good idea.if you search there's been a bunch of them.rear bumpers and brackets is another one that could qualify for faq it comes up alot.that's up to the kimosabe's of this forum i guess?maybe they'll get time to review it.
" Never look up a dead dogs butt." ![]() Last edited by boatpuller; 10-18-2008 at 02:20 PM. |
Re: Sway bars!
My 87 silverado 2wd swb came with no sway bar from factory. I have been looking high and low for parts trucks in the local area with factory sway bars (including suburbans and 3/4 and 1 ton trucks). Have found nothing. Plus, I think it would be hard to remove the old sway bars with basic handtools in a dirt lot. I am going to buy an aftermarket from summit. I am hoping to see and improvement since the truck corners like crap now.
I think I will pass on the rear sway bar for now. |
