Old 10-23-2008, 01:13 AM   #1
scrapmetalart
Junior Member
stepped lower control arms/ raised ball joints???
anyone done it? I have 3" springs & drum brakes on my 67. I wanna keep the drums cause I'm cheap...
are 67 - 72 lower control arms the same, just the ball joint different? I have a pair off a 72 & would like to do them so I can just swap them out...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 10-24-2008, 03:31 PM   #2
powell72
powell72's Avatar
Re: stepped lower control arms/ raised ball joints???
Yes, the arms are the same, the ball joints are different. Here's a pic for reference.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 10-24-2008, 06:27 PM   #3
67dragtruck
67dragtruck's Avatar
Never thought of that one before. I've seen the spring pocket lowered, but not that one. Does this cause alignment nightmares?
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 10-24-2008, 09:06 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Im pretty sure this used to be a common thing "back in the day", but I wasnt around then
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-24-2008, 09:27 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it was common.
If you are working it yourself, i think I'd recomend making the spring pocket deeper. That would be easier to judge how much of a drop you get, and no chance of messing up where the ball joint sits (screwing up the alignment)
I have a set, on the burb. I'm still not 100% sure they are gonna be on there long term. I don't think mine were built right. With no shims in there, I still have my wheels sitting like this;
Not to that degree, it is very mild, but enough to eat tires if I don't do something soon.
Old 10-24-2008, 09:49 PM   #6
scrapmetalart
Junior Member
longhorn...yours have the balljoint raised?
any one have pics of the spring pocket lowered?
Old 10-24-2008, 10:18 PM   #7
Longhorn Man
yeah, i may be mistaken, but that might actually be my photo. not sure.
But I DO know this is mine;
Old 10-24-2008, 11:09 PM   #8
scrapmetalart
Junior Member
looks like about 1"? I am thinking 2"...I will look into the dropped pocket. There is a guy not to far from me that does a TON of bags & lowered cars & trucks. I may ask him some stuffs...
Old 10-24-2008, 11:19 PM   #9
SactoJim
SactoJim's Avatar
Had mine for a long time......got them before all this other cool stuff was available.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-25-2008, 12:14 AM   #10
scrapmetalart
Junior Member
did you need the tube uppers to correct the alignment????
3" lowered springs & 2" stepped lowers?
Old 10-25-2008, 08:15 AM   #11
68C15
blood type; Retumbo
68C15's Avatar
mine used to have 3" lower buckets. that netted me a 5" drop. I also changed the angle of the ball joints to keep them in the middle of their arc. to do this I did 2 small slits and heated the arm while gently bending the ends. my way ended up with a neutral camber curve. the problem was the coils would rub on the inside of the pocket and make a ugly noise.
68C15 is offline   Reply With Quote
Old 10-26-2008, 12:37 AM   #12
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I had a set of "dropped A arms" from So Low Suspesions (back in the day). The first set were too wide and I could not get my camber even back to 0*. They sent me a second set which worked fine. Only issue I ever had was without any bumpstop, I overflexed a new upper ball joint and distroyed it. I replaced it and sold the truck soon after (not for that reason) so I never made any bumpstops, which would have fixed that issue.
Outside of that, they worked fine.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-26-2008, 12:46 AM   #13
SCOTI
SCOTI's Avatar
My buddies dropped a-arms (aftermarket So-Lo/Chisolm) worked fine up until the day one of the dropped spring pockets snagged a man-hole cover in his neighborhood. Bent the frame like a cartoon. . ..... the damage was baaaaaaaaaaad.
Stepped stock arms (like pictured) will work; but they'll have the same draw-backs vs. upgrading to drop-spindles.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-26-2008, 08:40 AM   #14
Longhorn Man
a drop spindle would have snagged on the same thing there.
In a dropped LCA that is properly built, I don't see any drawbacks over a dropped spindle.
Old 10-26-2008, 12:36 PM   #15
SCOTI
SCOTI's Avatar
I disagree.
The reason why is these were aftermarket dropped a-arms (which I indicated). The spring pocket was about 1.5" below the same lowest point vs. the stock lower arm it was swapped for.
I agree.
I feel properly stepping a set of stock arms would be similar to dropped spindles.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-26-2008, 02:07 PM   #16
Longhorn Man
I missed that part.
Thanks for the correction.
Old 10-28-2008, 11:58 AM   #17
MickMc
MickMc's Avatar
MY 68 3/4 had steped lower arms from So-Low, I put a lot of miles on that truck and I still see it driving around once in a while.
i still miss that truck...
Steped lower arms and cut coils, back in the day...
Mick
MickMc is offline   Reply With Quote
Old 10-30-2008, 07:51 PM   #18
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
Post deleted
New thread started
Last edited by MT71c-10; 10-30-2008 at 08:02 PM. Reason: started new thread. Too many questions
MT71c-10 is offline   Reply With Quote
