10-23-2008, 02:33 PM | #1 |
Will newer model power disc brakes work for 67-72 trucks???
Can I go to the salvage yard and pull power disc brakes off say a 78' chevy and it bolt right up to my truck?? or is it more complicated than that? I would really like to get power disc brakes on my truck for less than a grand
10-23-2008, 03:12 PM | #2 |
It's a catastrophic success.
Re: Will newer model power disc brakes work for 67-72 trucks???
71 and up had disc brakes 70 and below had drums. You have a few options, replace the whole cross member or pull A arms and spindles plus tie rods,pitman arm
10-23-2008, 03:47 PM | #3 |
I am a Referee of life.
There are a dozen or more ways to do it.You should use Krue's excellent FAQ's list to search all the options and pick which works for you.You can also check out some of the BB vendors for drop spindles and springs.They can set you up with 6 lug kits also.
JFYI,The 78 spindles on out will work but you will need to do some ball joints to match.There are also some differences in the tie rod ends.Again I suggest going to the FAQ's and reading up on what all needs to be changed.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 10-23-2008 at 03:49 PM. |
