10-26-2008, 01:10 PM | #1 |
Gone for a while, another big problem
My truck's temp gauge has been reading hot for about a week now, maybe more, but it was in the shop for a while, and I think it started "overheating" before then. I made sure there were always liquid in it, and it didn't seem to lose much if any coolant. That was until last night.
I had to drive about 2 hours roundtrip yesterday, and couldnt get an alternate vehicle. when I got to my destination, I heard boiling/bubbly coolant sound. It was strange though because my temp guage wasn't as high as it normally was. Anyways I put some more coolant, because it finally started losing a fair amount(.5 to 1 gallon) of coolant. on the ride home I knew it was going to be a headache. about 10 miles from home I heard a pop(pretty sure it was my temp guage which I found later to be destroyed) and luckily as it stalled out, I was only a little walk from a 7-11 which sells coolant. I needed a lot as it all was sprayed over the front quarter panels and inside of my engine compartment. I originally thought this problem was going to be my water pump. THis morning I go out, put about 1.5 gallons of coolant in it started it up, to look for leaks. It started, and was ok the first time. I shut it off and my spill over resvervoir was filling up, again with lots of air(i think) in the process. I dumped that reservoir because it was dirty(i think it was from the resevoir as much as anything. I squeezed the radiator hoses, and started seeing some leaking from the front of the engine, and at one of the hose/radiator links. When I started it again, for the first time today the exhaust manifold were steaming. Obviously fluid(coolant) is hitting the exhaust manifolds. Is this a tell-tale sign of a blown head gasket? if so how do I check for a cracked head, if i decide to do this myself? I would really like to do it myself after just spending $900 in the shop. and missing the best month of the year without my toy. |
10-26-2008, 03:20 PM | #2 |
urban fourwheelin
Re: Gone for a while, another big problem
what's the oil look like?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
10-26-2008, 03:28 PM | #3 |
the oil on the dipstick is a little low, but looks normal. Should I do an oil change?
10-26-2008, 03:32 PM | #4 |
urban fourwheelin
no, don't do an oil change. I was wondering if any coolant had got to the oil(it would look like chocolate milk). It does kinda sound like blown head gaskets or cracked heads...not good either way.
Have you ever disassembled the top end of an engine?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. Last edited by RED72blazer; 10-26-2008 at 03:33 PM. |
10-26-2008, 03:43 PM | #5 |
No, but my neighbor has. There is definitely leaking from my cylinder head bolts. I had chocolate milk in my coolant reservoir. where do I look for cylinder head cracks. Mine are aluminum. the PO really didnt do much right at all.
10-26-2008, 04:35 PM | #6 |
urban fourwheelin
you will need to pull the heads and take them to the machine shop.
10-27-2008, 02:20 PM | #7 |
Aluminum doesn't crack usually unless it is run hot without water, so you might get lucky? Pull the intake and heads, the MLS gasket is about the best out there since aluminum and steel heat and cool differently, you need a gasket that'll handle it. Sounds like maybe a blown head gasket, water level going up is a sign that compression is getting into the coolant, and would make the water dirty. Pull it apart and the gasket will be pretty obvious, and a crack might be as well. As for the initial problem, maybe a thermostat. Never trust a 40 year old guage to do anything but sit there, a $50 set of three guages would have alerted you early on, but if you drive it once you think there is an issue, you'd still be in this deal, just fix it remember this, learn from it and go on, experience is expensive sometimes. Good Luck.
