Old 10-28-2008, 11:01 AM   #1
chip46wis
Stock Proportioning valve
Heres what I want to use on my 69 step---I converted it to disk front only(from a 85) and I want to use a stock master and booster from the 71 type for disk-drum combo.I can buy the stock type for under $100 but I cannot find a stock type proportioning valve anywhere,anyone actually know where I can buy one? Thanks Chip
chip46wis is offline   Reply With Quote
Old 10-28-2008, 11:35 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Stock Proportioning valve
If your local parts store dont have one
http://www.inlinetube.com/Prop%20Valves/pro_valves.htm
sneakysnake is offline   Reply With Quote
Old 10-29-2008, 08:31 AM   #3
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
X2 InlineTube
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 10-29-2008, 09:01 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Good info on proportioning valves...
68gmsee is offline   Reply With Quote
Old 10-29-2008, 08:51 AM   #5
nightmare
nightmare's Avatar
IIRC i got mine from ECE: http://www.earlyclassic.com/catalog.aspx
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 10-30-2008, 11:42 AM   #6
OLDIRON69
Mike's bump and grind here on the board was the most reasonably priced when I did my drum to disc swap. I di get my lines from inline though.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 10-30-2008, 02:27 PM   #7
SCOTI
SCOTI's Avatar
I tried repeatedly to re-set the prop-valve on my 74 following instructions from here but it wouldn't work so I just got a new one & haven't had a prob since (7-07). I used Inline-Tubes valve & 4pc front stainless hardline kit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
