Be nice, it was a work truck!
Turning left, and right...
Who here not only does the straight line racing, but also takes their trucks to the autocross events and race tracks??
I have a 70 LWB, which isnt the "ideal" platform for turning corners, but oh well. My plans are a 4/6 drop, and probably 18s all around. But I am open to suggestion. Any pics or info will be greatly appreciated! |
Re: Turning left, and right...
The front/rear weight ratio is the biggest killer. Anything you can do to shift weight toward the rear or lose it altogether will help. Huge sway bars will also help. That will stop body roll which in effect balances weight from side to side. You are probably going to need to up-grade the brakes too. Big wheels can add to the un-sprung weight, so keep them as light as possible. A heavy wheel/tire combination can have negative effects on steering and braking.
#3 | |
I'll also be running a serious 4 wheel disk setup, and big sway bars. |
If your not keenly 'schooled' in suspension theory & the impacts of loading/un-loading & set-up of the suspension, a 'kit' from one source that's designed w/your goal in mind would help consideribly (ART's Street Challenge stuff or something similar). Then it's just a matter of tuning a system vs. a sum of various parts that may or may not want to work together.
Check out stock car products for all kinds of good stuff that can be adapted to these trucks if the kit approach is not for you. Another option (which also can shave some weight) is Porterbuilts C4 Dropmember. Better geometry & easy to adapt bigger brakes. As mentioned weight control & distribution will yeild big benefits & the importance of sticky tires can't be stressed enough. No 'posing' if you're lookin' to run a decent number.
#5 | |
I have a pretty healthy knowledge of suspension and the like. I modified the suspensions in my 88 T/A and 94 Z28 that I owned previously with pretty good results. What I have seen so far is gmcpauls 4" disc brake conversion kit, cause I have the C/20, with 4 wheel drums, and that has to be fixed pronto! I will have to check out the C4 dropmember you mentioned. Thanks! Frizzle Fry - Awesome videos dude, that's exactly what I was talking about!! I already had inspiration, but those just reinforce it! |
Any more info on what you currently have as well what the budget you're trying to accomplish the goal on? Knowing that will help us suggest the best options.
![]() Join Date: Aug 2005
Not the best videos (camera man didn't know how to use zoom and the audio gets out of sync)... Not the best driving either, but hey I didn't come in last
Junior Member
Frizzle.... thats cool brother!
I had a 1.25" front bar and 4th gen camaro rear bar with poly ES bushings at that time. It was dropped about 4/5.5 and had KYB's all around. Front discs and 17" wheels. It was no G-Machine but it was a huge improvement over stock. Too darn long though...
![]() Last edited by Frizzle Fry; 10-31-2008 at 01:28 AM. |
Yep.... and that can't be changed. Or can it
Truthfully, the stock suspension parts can be made to work pretty well. As said before, mounting the engine/trans as low and far back in the frame as possible would help alot also. But you really need to do something about the frame though. The stock frame simply doesnt have nearly enough torsional rigidity to do anything seroius with. All the best suspension stuff in the world wont help much if the frame wont let it do its job properly.
#13 | |
Is there any difference in the frame rigidity of a 1/2 ton and 3/4 ton? |
#15 |
#16 | |
I'm doing C4 front end w/ShockWaves (dbl adjustable) up front. The rear will utilize either a modified version of the truck arm suspension w/a Watts link or a parrallel 4-bar (depending on space limitations). My goal is to bring the springs out as far as possible on the rear end within my wheel back-spacing limitations & add as many additional c.members as possible to increase torsional strength. Alum a-arms, spindles, brake pieces, radiator, heads, water pump, & relocating the batt to under the bed will help off-set my weight gain up front (BBC/4l80e). But the BBC torque curve will help scoot the portly truck along nicely w/o having to be excessive (and still be old school w/those big ole valve covers).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-02-2008 at 02:15 PM. |
#17 |
The 67-72 3/4 ton frames use the same rails as the 1/2 ton. They do have additional triagulated braces in front of the TA/carrier crossmember. Maybe more, but those for sure. Those won't add much for torsional rigidity.
An old-school trick is to weld the existing cross-members to the side-rails. That alone increases torsional rigidity over the factory rivets. A step beond that is to box the rails and add one of these (pic courtesy of Progressive Automotive) : ![]() |
#18 |
When I boxed mine I did a experiment to see what it would really do. I put the frame on jack stands under the lower control arm cross shafts in the front and under the shock crossmember in the rear.
Before the boxing when I put a jack under the right rear of the frame I was able to jack up the right rear over 10 inches before the frame came off the left rear jack stand and I ran out of travel on the jack before the right front of the frame came off the jack stand. After the frame boxing, welding in the crossmembers and some other light bracing I was only able to jack up the right rear about 2 inches before the left rear came off the jack stand and around 4 inches before the right front came off. While not as good as a full cage, hopefully it will help somewhat. I also own a real sports car and I dont expect my truck to ever handle like it does but Im hoping it will be at least as good as new pickup(which really arent too bad considering). |
#19 | |
#20 |
#21 |
There's always the guy who swaps in Vette suspension parts into his truck & then complains that it doesn't handle like a Vette.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-03-2008 at 01:47 PM. |
