10-29-2008, 04:30 PM | #1 |
busted knuckles
Leaning a little
I cut 2 coils off and now I have a little gangsta lean. Has anyone else had this problem. I cut them the same on each side. |
10-29-2008, 07:27 PM | #2 |
New Member
Re: Leaning a little
when i first lowered mine i cut two links and i had the same problem,a front end shop told me the springs were wore out and when you lower them its alot more obvious i called ece and bought springs and they told me the same thing,popped in new springs and the truck sat right,hope this helps.
10-29-2008, 08:27 PM | #3 | |
Tot Roddin'
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-29-2008, 08:52 PM | #4 |
make that 3
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
10-29-2008, 09:04 PM | #5 |
Tot Roddin'
Sounds like your springs are just worn out... call ECE (Early Classic Enterprises)
10-29-2008, 10:34 PM | #6 |
Happy to be here
Are you sure they are clocked correctly in the spring pockets? If one is not seaed in the groove it will make it sit higher...
