Old 11-01-2008, 12:07 PM   #1
eric67m
eric67m's Avatar
Do you like it dry or prefer some lube?
Sorry, I couldnt resist the title.
On my sm465/np205 that I just put together. I greased the coupling between them. After doing this I wondered if that was a good or a bad Idea? I know that the adaptor area is "dry" so I figured some lube might not hurt. But any wear and metal shavings would stay right on the shafts and potentially wear more.
Before I put them back in the truck, should I pull them back apart and remove the grease or will it not be a problem?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 11-01-2008, 02:04 PM   #2
kwmech
Re: Do you like it dry or prefer some lube?
I always grease them up. Keeps them quiet, and somewhat prevents rusting
Old 11-01-2008, 08:47 PM   #3
Wreckless_71
Wreckless_71's Avatar
yep... lube it.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
