np203 in a 69 k10
I am trying to install a 203 transfer case with a th400 out of a 77 chevy in my 69 k10. The 203 hits the floor of the cab, so I thought about making spacers to drop the crossmember but then my distributer (H.E.I) hits the fire wall and I don't really want to do a body lift. I'm sure I'm not the first to put a 203 in a 67-72, so I'm just curious what others have done.
Re: np203 in a 69 k10
cut a hole in the floor or go with a 205....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
I thought about cutting the floor, but the only problem is that where it needs to be cut is right on the seem of the tranny hump.
you have a highhump floor? Can you make a metal cover for the cut? As long as it doesn't hit your seat then you should be good...
How much is hitting? You could extend the high hump with a little fab work...
When the 203 hits the floor the cross member still needs to go up about an inch. I'm not sure how much clearance is needed between the floor and transfer case, but yes it is a high hump.
I have a high hump from 77 w/203(yellow), if you want to do some grafting.
Shown here next to a high hump from a 72 w/205. ============================================================ ![]() |
I just put new cab mounts on it a few years ago, but I only drove it a few hundred miles since then. Thanks for the offer Cyclone, I work over in Sonoma once in awhile so if I decide to go that route I will let you know.
Born Psycho
![]() Join Date: Feb 2001
if you are using the crossmember originally under your rockwell, it must be spaced down a little. i went through the same thing years ago when i put a 205 in my 69. i'm sure someone here has a 205 crossmember that they will sell you.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
How's your cab mounts? sagging?
