Old 11-05-2008, 11:47 PM   #1
hobsiscool
engine question
Ok...I think i'm kinda leaning toward building the inline, however i'm still having some trouble figuring out which head I need to get...if someone has pictures or can point me to an ebay auction, etc of one, that would be awesome...second, before I can do any of that, I need to figure out what's going on with my engine...I'm about to take it in to get looked at, but it would be nice to get some ideas here...it runs fine, idles fine, it just makes a loud clacking noise and smokes...what could this be??
Also, will a TH350 bolt up to my engine without any modifications?
Thanks guys
hobsiscool is offline   Reply With Quote
Old 11-06-2008, 07:21 AM   #2
D13
D13's Avatar
Re: engine question
A TH350 bolts up assuming your flex plate has holes that match the torque converter. If you did not have a TH350 or 700R4 you will need to rig a kickdown cable.
Look about 3-4 pages down for a thread 'where are all the 6 bangers?' started by Manimal. On Page 2 there are some good shots of non-integral head engines, basically showing where the intake can be unbolted from the head.
http://www.inliners.org/tech/heads/headindex.htm has a partial list of head castings. Avoid the nova siamesed exhaust ports, and watch your compression ratio.
Occasionally heads show up on ebay but shipping will kill you. I find an l6 a month on craigslist.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 11-06-2008, 09:04 PM   #3
hobsiscool
Re: engine question
is this a non integrated head?
http://cgi.ebay.com/ebaymotors/CHEVY...es#ht_1057wt_0
Old 11-06-2008, 09:16 PM   #4
hobsiscool
Re: engine question
i'm thinking it's for the wrong engine, i just saw the casting number..thinking it may be for a 454...i don't know, i'm new to the chevy scene.
Old 11-07-2008, 07:41 AM   #5
D13
D13's Avatar
Re: engine question
use the search (chev*, GMC) (250, 230, 292) for a starter, then look at what you don't like and add - strings.
And that is a V8 head.
1987 2 ton
Old 11-07-2008, 09:30 AM   #6
manimal
manimal's Avatar
Re: engine question
Go to your local wrecking yards and look for a head froma 194. A 230/250/292 head will also work. A 194 will raise your compression ratio,but shrouds the valves. Are you building a 250? 292?....more info please.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 11-07-2008, 02:54 PM   #7
hobsiscool
Re: engine question
it's a 250...i've got an appointment monday to get my truck looked at so hopefully i'll have more info as to junk it or fix it (the engine that is) so we shall see.
Old 11-07-2008, 07:46 PM   #8
manimal
manimal's Avatar
Re: engine question
for the 250 you can use 307 flat top pistons(cast are fine). Take a look at webrodder.com There is someone on there makes cams just for the inline 6's. Good Luck.
-Lance
-Lance
