11-10-2008, 11:22 PM | #1 |
Air bag suspension?
I am considering buying a truck with an airbag suspension and I know very little about them can anybody explain them to me and any pros and cons of them.
11-11-2008, 12:07 AM | #2 |
Re: Air bag suspension?
i'll try pros: adjustable suspension, decent ride quality, looks awesome when parked
cons: system failure(lines burst, bags burst, leaks, faulty valves, faulty compressor, broken guages)
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! |
11-11-2008, 12:52 AM | #3 |
Thanks.....So you can adjust the ride hieght?.....and set it on the ground when parked?....also how often do the cons happen? Are they common if the system is done right?
11-11-2008, 01:48 AM | #4 |
Chevy Truck Addict
It depends on the system, but on most you can control the ride height from inside the truck. I would say failures are not common at all if the plumbing is done right. Make sure your lines are well routed so that they aren't being pinched or come into contact with the exhaust and you should be fine. Next time you pull up behind a gravel truck or semi, take notice of what is holding the load up... Air Bags. If they were prone to failure, I don't think they would install them on every rig on the road. Go for it... I love the bags on my truck.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . Last edited by C10-Driver; 11-11-2008 at 01:50 AM. |
11-11-2008, 09:35 AM | #5 |
Thanks......good to know.
11-11-2008, 09:40 AM | #6 |
Happy to be here
If a system is properly installed you should almost never have a failure. Keep in mind that most big rigs, commercial buses and large motor home ride on air suspension. It's reliable if applied properly.
11-11-2008, 02:16 PM | #7 | |
Properly installed is a must have. Quality components are too.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-11-2008 at 02:17 PM. |
11-13-2008, 12:24 PM | #8 | |
Consider it like compressors are an alternators and bags are like tires. Better products usually yield better results. But most problems arise from poor installations, seen it time and again here. |
11-13-2008, 01:25 PM | #9 |
Excellent comparison!
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-13-2008 at 01:25 PM. |
11-11-2008, 03:17 PM | #10 |
Cool thanks for the input guys keep it coming.....So Scoti it sounds like you system doesn't have its own compressor?....is that the most common setup?....some have their own compressor right?
11-11-2008, 04:24 PM | #11 | |
My budget (and many others as well ) determined the set-up for me.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-11-2008 at 04:25 PM. |
