11-13-2008, 12:05 AM | #1 |
advice on speaker placement
72 c20. just put in stereo, 5 1/4 in doors (cut by po). where to put some 6x9s? put in a set of buckets from a 98 chevy truck, but i don't know if they are staying in. feel like i am sitting too high and too close to st. wheel. the tank is still in the cab, and i have no imidiate plans to relocate it, although that would solve a lot of problems. So if the stay in, i will build a box to put between them, but if i put the bench back in, where can i put the speakers? i could make kick panels, but it seems they may be in the way. any ideas? any kick panel plans you guys have out there? a pattern would be nice, im no carpenter! let me know what y'all did, give me some ideas............thanks.
72 c20, lwb, 402 project/driver....sold Looking for swb for son's first ride! 66 el camino, 350, 4sp., new front suspension! 99 chevy 4x4, daily driver 2000 yukon xl 4x4 2500, wife's driver! 46 willys jeep, ohc 4cyl ford, it's a blast! Of all the things I've lost, I miss my mullet the most! |
11-14-2008, 07:15 PM | #2 |
Re: advice on speaker placement
I am having the same dilenma, because of the gas tank and keeping the benchseat, so I will be watching this thread closely.
bump for you!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
11-14-2008, 09:20 PM | #3 |
Relocate the gas tank or put some shallow mount subs under the bench seat.
11-15-2008, 02:47 AM | #4 |
>130dB Moderator
What you can do is create a special box (can't remember the name of it right now, where you build individual boxes for each 6x9, but then link them via a large PVC pipe and cut a port into it in the middle.
Basically it would look like a large pipe with the speaker boxes as book ends. You would need to put the two speakers as far apart as possible and cut the hole for the port in the dead center of the pipe. This configuration can give two 6x9's relatively the same output as a 10-12" sub.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
11-16-2008, 11:19 PM | #5 |
sounds like a cool idea, may give it a try if i put the bench back in. I built a box for it today, threw the speakers in to test it out. it sounds ok, but of course could be better. i'm used to the systems in my other vehicles. anyway, the buckets are still in. i hooked them up to power and adjusted them as much as i could to get them as low and as far back as posssible. permenent power will be supplied if they stay. i need to drive it for a while to decide. anyway built the box between the seats, it looks similar to the sillouete of a chair. both 6x9's are set in there at opposite angles, and both facing forward. i didnt have room for the original plan, which was to make a dog house shape so they would face the driver/pass, but no room. So, it could sound better. i'm sure it sounds good to the windshield! i also made it in this shape to help hide the gas tank, since the buckets don't really cover the middle! i can take pics if anyone is interested. let me know! again, it's not yet covered with carpet, but will be soon. let me know if you want to see it. i will update if anything changes.
11-28-2008, 02:17 PM | #6 |
Grandpa in the rustmobile...
does anybody have plans to make there own kick pannels im quite intereested in this...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-28-2008, 04:53 PM | #7 |
kick pannels will sound the best. i built these. plenty of room and the ebrake is out of a toyota...
11-28-2008, 07:21 PM | #8 |
Well I took my pioneer 6 cd changer out from under the seat (proly shouldv'e left it) and took my cheapo speakers out from under the seat in there plastic rattly boxes...and pulled my head unit (old as heck its cassette)..so in the market for newer cd player head unit and..proly some kidna kick pannels (frostie, howd u make yours)^^^?? i like em!
12-01-2008, 03:43 PM | #9 |
its fiberglass and two part foam
