inner frame rail spacing
hey guys, considering mustang 2 x-member, what is the actual measurement between the frame railson a 59 p/u?????
thanks. |
I checked the factory assembly manual and found that the outside dimension at the front frame horns are supposed to be 34 inches. Mine measures the same. I then checked the inside measurement at the centerline of the radiator mounts. This measured 30 inches. I hope these measurements help.
Not-E-Nuf
thanks, i appreciate it, that does pretty much match up with a measurement i had available of 29 3/8". i suppose tht's about right, thanks.
| Bookmarks |
