Will I need a C Notch ?
My frame is rolling with no motor and I was wondering if 7 inches from the top of the axel tube to the bottom of the frame is enough travel? Aslo if anyone has a stock hight frame could you get me the distance from the top of axel to bottom of frame . I just want to see How much My truck is droped I estimate about 5? but not sure . Thanks .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
7" is plenty of room. You shouldn't have to worry about notching your frame. You can drop a full 6" before you need to worry about a C-notch kit. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
ttt
Fabricate till you "puke"
I have 3 " clearance tween the frame & axle on the longhorn......no bumpstops,& no bottoming.
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
I have a 5" drop in the rear and haven't bottomed out yet. Still have the bumpstops and all. Of course I'm not towing anything heavy either. No C-Notch for me. You should be good. I have probably around three inches or so of travel.
68 SWB The Surgeon General doesn't say anything about smoking a Ford!!! Would rather be ran over repeatedly by a Chevy than drive a Ford!!! Paralyzed from the neck up and confined to a hat! Kathleen, Georgia USA |
GMC SHORT FLEET F/S
Just notch it and dont worry about it!
CHARLES WADE HEIN HVACR FOREMAN. LEWISBURG U.S.P. |
