Old 11-16-2008, 05:28 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Question Help with OEM Tach Issue!
does anyone know if there is supposed to be an isolating fiber, plastic, or rubber washer between the rear mounting cup and the "12V" and "COIL" posts. this is not to be confused with the red plastic washers the mount under the spade connectors.
the two posts are going to ground and believe they are suppose to be isolated.
anyone have a factory exploded view of an 8 cylinder tach?
THANKS!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 11-16-2008, 09:08 PM   #2
tcb-1
tcb-1's Avatar
Re: Help with OEM Tach Issue!
here's a pic of what I'm talking about. is there some type of isolation washer between the mounting cup and the brass mounting posts??
Doug
Old 11-16-2008, 10:05 PM   #3
chevy29267truck
im not sure about that
chevy29267truck is offline   Reply With Quote
Old 11-17-2008, 10:47 AM   #4
tcb-1
tcb-1's Avatar
any thoughts, guys?
ttt
Doug
Old 11-17-2008, 12:31 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
I have a factory set up that was working when I pulled it. I would have to pull the cover to look at it. May take me a few days toget around to it. My brother has my assembly manual, and I am not sure if it is covered there anyway.
WIDESIDE72 is offline   Reply With Quote
Old 11-17-2008, 01:53 PM   #6
tcb-1
tcb-1's Avatar
thanks wideside. it's not covered in the manual, so taking the backing cup off the tach assembly is really only way to tell.
I'd be very thankful if you could check for me!!
Doug
