11-17-2008, 08:35 PM | #1 |
5.3 Swap w/Stock Radiator.....Which Hoses?
Hey guys, basically I just need to know if a set of stock upper and lower radiator hoses from the intended app will work with my truck stock type of radiator.
I don't have my radiator yet (on its way from another member). More or less I am just worried about the inlet/outlet sizes on my stock radiator VS the size of the hoses. I know there have been more than a few of you that have swapped in a 4.8/5.3/6.0 truck LSx in your own trucks and have been down this road before. Thanks guys!!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
11-17-2008, 11:31 PM | #2 |
Re: 5.3 Swap w/Stock Radiator.....Which Hoses?
I used the factory 5.3 hoses. You have to lube them a bit to make them slip on the rad outlets, but it works.
