11-17-2008, 11:15 PM | #1 |
Truck CRAZY!
89 - 91 grill swap blinker question
Ive swapped the core support and started the wiring. Ive got everything wired in and when i turn the park lights on the marker light on the fender blinks on and off and so does the inside marker light in the grill but the outside stays on and blinks does anyone know if this is right? Also when the park lights are turned on the blinker slows down is this normal?
84 Chevrolet stepside, 350 with .60 over pistons, aluminum zr1 heads, doug herbert .500 lift cam, 1.6 roller rockers, elderbrock intake with a 600 holley carb, mated to a 700r4, 208t-case and 4-11 gears,33 goodyear wrangler mtrs |
11-17-2008, 11:21 PM | #2 |
In the Forgotten far North.
Re: 89 - 91 grill swap blinker question
Both front facing bulbs should flash together while the side marker lamp will flash alternatingly from the front lamps. If it's slowing down as you say I'd double check your grounds.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
11-17-2008, 11:27 PM | #3 |
BAD BOW-Silverado XST
Yes!! On my setup, when the lights are off the both front turn lights flash together. With park lights on, the front two alternate!! The inside flashes with the fender light!! Looks cool at night.
