11-18-2008, 02:05 AM | #1 |
Gripnrip
8 lug wheel swap
Can anyone tell me if 8 lug 3/4 ton wheels from a 95 or newer chev will fit my 71 chev 3/4 ton? I have been told the offset is different and may cause problems.
11-18-2008, 02:13 AM | #2 |
Re: 8 lug wheel swap
lol... mine are off cummins dodge, :-)[/IMG]
11-18-2008, 02:32 AM | #3 |
Resident of Here
They should fit, but the bore is a little smaller I believe.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
11-18-2008, 02:36 AM | #4 |
I had newer Duramax alum. on mine no problem
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
11-18-2008, 06:59 AM | #5 |
its all about the +6 inches
the offset is a tad off, and it looks a little funny if you stare at it for a while, otherwise 88 - 98 wheels fit fine, but are a total PITA to remove.
11-18-2008, 09:02 AM | #6 |
I don`t think the 8-lugs are as inset as the 6-lugs.
11-18-2008, 09:03 AM | #7 |
Yep they work-
I had the original split rims on mine when I bought it and the offset was actually the same.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
11-18-2008, 10:56 AM | #8 |
Ace in the hole what lug nut did you use to hold on the center cap? Did you change the wheel studs.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 11-18-2008 at 10:57 AM. |
11-18-2008, 12:58 PM | #9 |
Gripnrip
Ace in the hole. Yeah! That truck is sweet and the wheels look great. I even like that green color. Do you know what the chevy name for that color is?
Thanks for the info and the pic. |
11-18-2008, 01:27 PM | #10 |
I got the lug nuts here- http://www.wheelcomponents.com/lugnuts.html 3rd row down, part #2004. I have been told that most tire stores can get them for you too. The hardest part was cutting the center out of the front caps to fit over the hubs. These caps have a thin layer of metal over the plastic, almost like stainless. Hard as nails to get thru. I had a brand new 4 1/2" hole saw and by the time I was done it pretty much was too.
The color is PPG #415570. It's not an exact match to the original med. olive but its real close. Since I painted the whole truck I was not worried about an exact match.
11-18-2008, 01:52 PM | #11 |
Here is a picture of mine, I love these late model rims on the older trucks. You can get them pretty cheap too as guys are switching out to bigger rims/tires.
12-10-2008, 02:34 AM | #12 |
yep fit just fine...12 bolt and 14 bolt, discs and big drums.
12-10-2008, 11:59 PM | #13 |
I'm running 82 Ford F350 steelies on mine (I've got dualys though..). The offset is fine, the rims are wider than the stockers.
12-11-2008, 08:04 AM | #14 |
Watch out for your cornhole !
The 8 luggers on my 3/4 ton came off a Ford van. Fella on Craigslist had em for sale.
