Old 11-18-2008, 11:02 PM   #1
Rreemo
Rreemo's Avatar
Looking for info on Van tilt column
My truck has been retro-fitted with a tilt column out of a van - appears to be late 70's - early 80's era.
My blinker return switch has never worked, and now my blinker arm has come loose. Pulling the steering wheel revealed that the small set screw that holds the arm is stripped. I think I need a new blinker switch too, but would like to see a diagram on this thing if possible....trying to figure out what all will need to be replaced.
Anyone havine information on these van columns?...and/or know if the parts for these things are available through places like Napa?
Thanks.
72' LWB Cheyenne
73' Camaro Z28/RS
70' Chevelle RagTop
00=ss=00
Rreemo is offline   Reply With Quote
Old 11-19-2008, 09:12 AM   #2
JimKshortstep4x4
Re: Looking for info on Van tilt column
The truck turnsignal switches are the same except for the indicator light which can be transferred over.
The part with the stripped threads can be replaced without pulling the switch. Pulling the switch can be a project so if no one else posts a schematic, I will snap a pic of the page in the repair manual.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-19-2008, 09:59 AM   #3
Rreemo
Rreemo's Avatar
Thanks for the reply. I can see that there is metal insert that goes into the backside of the plastic switch - that insert is what the securing screw for the lever goes into. Not sure where I can get one of those.
Can you tell me how the cancel function works? I can't tell from looking at it why the turn signals do not cancel....I'm wondering if there is a part missing, or if something is broken with the switch itself.
Thanks again for any help you can provide.
72' LWB Cheyenne
73' Camaro Z28/RS
70' Chevelle RagTop
00=ss=00
Old 11-19-2008, 01:54 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Here is a breakdown pic I have.
sneakysnake is offline   Reply With Quote
Old 11-19-2008, 06:36 PM   #5
JimKshortstep4x4
There should be two springs that are on the switch itself. If one or both are broke the cancelling will not work. Or it could be caused by the part that is broke.
I will check to see if I have an extra part like you need.
Jim
Old 11-20-2008, 12:41 AM   #6
Rreemo
Rreemo's Avatar
Jim
Thanks Jim - both springs are in place and appear to be in good shape....I will take a picture of what mine looks like and post it up tomorrow. I think I might just be missing some parts in this thing, but for sure will need the little metal nipple piece that the blinker arm secures into.
Thanks again!
72' LWB Cheyenne
73' Camaro Z28/RS
70' Chevelle RagTop
00=ss=00
Old 11-20-2008, 12:15 PM   #7
JimKshortstep4x4
I have a good cancelling plate assembly but not the little pin, (the ones that I have are broken). The cancelling plate can be replaced without having to remove the switch.
Hopefully someone will have a good pin but if you need a cancelling plate without the pin, let me know.
JIm
