Gearhead
TV Cable
So I have been consumed by this LT1 swap and I am getting to the final stages, but have run into a slight snag..... I purchased the Lokar throttle cable, kick down (TV) cable and bracket, and installed them, my question is has anyone else used this set-up on an LT1/700R4? I am questioning the operation of the cable because when I set it for WOT, there is excessive play at the idle position? I had considered redrilling the arm they add to the throttle, but thought I would ask first. Thanks
Moderator
![]() Join Date: May 2007
Re: TV Cable
www.bowtieoverdrives.com has some excellent info on how to set up your TV cable
Gearhead
Re: TV Cable
Thank you very much, I checked out the site and read a ton of info, called them and they were very helpful. I HIGHLY receommend them to anyone else as well.
Thanks Again |
![]() Join Date: Apr 2005
Re: TV Cable
I had that set up on my 48 and never had any issues with it.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Gearhead
Re: TV Cable
Hart_Rod that is a sweet ride! Thanks for the inout, I was a little scared of it at first LOL
still buypickupparts
Re: TV Cable
I see you have a vacuum line with the one way valves on the line from your opti spark distributor, is your motor a 94? and can someone tell me if a 94 has a vacuum line from the opti spark distributor that connects to the intake, like in the picture? on the LT motors
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
#7 | |
Re: TV Cable
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm http://www.fierolt1.com/top-end.htm http://www.fierolt1.com/bottom-end.htm
Re: TV Cable
thanks Hart_rod
Gearhead
Re: TV Cable
My LT1 is from a 96' Camaro, I think the vented opti-spark didnt start til 95', if memory serves me correct.
