Zero Rate/Add-a-leaf in front
I'm thinking of using some salvage yard or my old rear springs in the front of my truck. I suspect either will have some sag in them. Is it possible to use add-a-leaf or zero rate springs level out the front if needed? Seems to me a zero rate spring is simply a lift block which bolts to the springs and I know lifting the front with a block is bad.
72 GMC Jimmy, 350, sm465 np205 (getting a face lift) 64 Nova SS, 327 SC & gassed, TH350. (blowed it up) 84 HD FX frame,80 FL tins, evo with 85hp/90tq (wifes bike) 96 HD FatBoy evo with 102hp/100tq (mine!) KEEP NOTHING STOCK! |
![]() Join Date: Feb 2000
Re: Zero Rate/Add-a-leaf in front
I believe Offroad Design sells a lot of their Zero Rate blocks. For a period of time I ran a home made set that were secured to the spring pack with a longer center pin, but honestly, I was never very comfortable with it. I have since replaced them with a different set of lift springs. I hated the thought of people looking under my truck and thinking he's using a lift block which is a no-no. In the end it was a band-aid to wanting a bit more lift. I got rid of them and now don't have to worry about what if the forces caused the center pin to break and one block came out.
I'm NOT saying they are unsafe - as that is beyond my level of knowledge. Just saying for me they ended up being a temporary thing. As for using the rear springs up front, I believe they are different lengths than the fronts so I doubt that is an option without going to the trouble of relocating their attachment points. You could add a leaf or two, but who knows what affect that will have on your spring rate/ride quality - I'm sure it won't make it better!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#3 | |
I just installed them....and it really is no different than adding a "real" add a leaf....It's just short....
ORD sell tons of them...I'm sure they are fine! I did it for the same reason as you...to just help a little with any sagging of the original leafs... One note: I had to drill out my front leafs to accept the slightly larger pin that ORD sent with the kit....That was tough, with just a hand drill as that steel is pretty hard.... Also, the kit included the wrong U-bolts for my application...so double check that! Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 11-21-2008 at 04:31 PM. |
Not a bad nut after all..
Did you install the ORD zero rates in the rear also? Do the rear springs have to be drilled out or does the hardware ORD proves fit (on a '70 in your case or a '71 in my case)?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer Last edited by badpeanut; 02-07-2009 at 10:17 PM. |
#6 | |
I did install them on the rear as well....and the rears leafs actually had the correct size hole to accommodate the new pin that ORD supplied....One thing on the rears though.....ORD sent the worng U-bolts for them.....as they said they did not have the square style factory type....so I wound up doing a U-bolt flip....and they sent me out new top plates.... Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
Well, it will hurt your spring rate but here is an idea. Tuff Country sells the EZ-ride and the HD front springs. You may be able to buy the extra bottom leaf that they use to make the EZ into the HD. A board member had the HD extra leafs and when I added the BBC I went to 6" EZ Ride springs and got the extra leafs from me and they gained right about 1" of extra lift.
I'm a poor spectator
You can use them up front, I might end up having to put some on my blazer. One inch is no biggie, it's when you start using blocks for 4 or 6 inch or more that you run into problems.
What i'm trying to say is don't do this... ![]() ![]() ![]() ![]()
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
#9 | |
![]() Join Date: Feb 2007
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Yeah it's pretty bad.
What's wrong with that?
love the fact that it is red iron too. some people's children...
zero rate add a leaves are OK. i am with Yukon though, it seems like a band aid fix. plus lower is better right? ryan |
#13 | |
Trying to get 39.5 or 42's under a 72 GMC Jimmy with a 6"inch lift. I'll already be cutting a bit and a saggy set of springs (most 20yr old springs will be!) means more chopping. I also like the idea of being able to tweak the axle position a bit.
Everything is work in progress
![]() Join Date: Apr 2006
If you only need to tune a little bit you might be able to get-ur-done with longer shackels. Mock it up and see what you have to do to get it where you want it.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
#15 |
Already getting 6" shackles with the DIY kit. Longer shackels go the wrong way with the pinion angle for the front so I'll probably stay away from that option. JustChevy is right up the road from me so finding some reasonable springs shouldn't be that hard and the guys are pretty easy on my wallet. I should have known trying to get this done within a reasonable budget wasn't going to work out. Once I get everything in and the truck on the ground I'll be able to tell where I'm at and go from there.
#16 |
I made my own zero rate block for the front. Used it to add about a 1/2" lift and move the axle back 1". I actually just welded them to the axle housing, figured not much chance of a problem that way. So far, so good. Just another option.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
#17 |
i,ve seen multiple full lenght leafs cut to about 4" sctions and use as 1"-2" high bolted to the pack is that safe?
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's |
#18 |
The first lift I did,that`s how I did the rear lift of 4".It worked fine.
#19 |
That's basically what zero-rate leafs are. I used short add-a-leafs in the back and it added 1.5". I might do long add-a-leafs or zero rates in the front if needed.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
