11-23-2008, 01:45 PM | #1 |
pkbinplano
Turn signal switch / wheel lock removal tool FYI
FYI if your replacing your turn signal switch, or rebuilding your column, Auto Zone has GM tool part number J2365-A, under tool number 27044 for $15. This is a must when removing and installing the wheel lock plate, as a big spring must be compressed when removing/installing a snap ring. They also have the turn signal switch for $25. Got as far as getting down to the switch, then put it back together untill next weekend. PS my switch has a broken return spring, and no, the new springs on the new switch isn't the same. Was going to just swap a spring. LOL
http://www.picturetrail.com/gallery/...7496&members=1 84 chevy silverado aka The Bananna Boat |
11-23-2008, 02:06 PM | #2 |
Re: Turn signal switch / wheel lock removal tool FYI
Personally I would change the ignition lock cylinder, and ignition switch while i was there, rather than removing it all again when it breaks
Duro
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
11-23-2008, 02:07 PM | #3 |
pkbinplano
good point
11-23-2008, 02:16 PM | #4 |
Sb 400 club
yeah that is what I would do as well. I don't have that tool but have removed plenty of locking plates. I can see how the tool would help. Since they used a different key for the ignition and the door locks you can get the tumbler form almost anything with the same column. I had one from a 94 c1500 column that had the black trim and black GM key that i put in my 89 wrangler. they all use the Saginaw column.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
