11-23-2008, 07:08 PM | #1 |
Truck Junkie
Oil Gauge
Anyone out there know if an after market oil line (plastic) will work or do i need to get a copper one...thanks!
11-23-2008, 09:02 PM | #2 |
sharp as a marble
Re: Oil Gauge
I would use copper. I have a low opinion of the plastic tubing. GM used nothing but copper for years.
11-23-2008, 10:24 PM | #3 |
Dave's not here, man
Re: Oil Gauge
I used plastic for awhile because I had it lying around. I switched it to copper though and wouldn't do plastic again. I think I paid less than $10 for the copper line and it's really easy to bend. I was always worried about the plastic rubbing something and getting a hole in it. Go copper; just my .02
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
11-24-2008, 02:05 AM | #4 |
Out of the carpool lane.
Re: Oil Gauge
Yep, go copper. But if you must have the plastic line, I'll give you the one from my Camaro as it's getting copper in the near future.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
11-24-2008, 07:11 AM | #5 |
Re: Oil Gauge
I had plastic let go a long time ago. Not fun, & what a mess. Ever since then, I use copper.
1997 GMC Sierra Ext 1965 Mustang |
11-24-2008, 08:33 AM | #6 |
Re: Oil Gauge
with copper so readily available why think plastic? go to NAPA get the good stuff
11-24-2008, 03:28 PM | #7 |
Truck Junkie
Re: Oil Gauge
Thanks Guys! Yep i'm guessing go with copper is the answer....
11-24-2008, 07:19 PM | #8 |
Active Member
Re: Oil Gauge
I agree with all of the above... The only time I've had an oil leak in my vehicle was whith a nylon oil tube. Oh, and when I buggered up the threads on a copper line.
11-24-2008, 08:03 PM | #9 |
Re: Oil Gauge
I had the plastic line bust years ago in my 66 Mustang.50 psi and carpet don't mix very well. Go copper, it wont let you down.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
