Retired Air Force Veteran
![]() Join Date: Aug 2007
I need new tie rods
I am converting from drum to disks and I need to replace the Tie Rods.
Should I replace the whole thing or just the end? What brand are you using? Where are you buying your parts? We have an Auto Zone, Advanced Auto, Napa and a few other local auto parts houses. Thanks
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Under Construction
Re: I need new tie rods
if they are original i personally would replace them all. We bought ours from Autozone, but NAPA would be a good choice. Get the ones made in America. Good luck with your conversion.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Are you using stock spindles, aftermarket, drop?
Some aftermarket spindles will let you use the original yr tie rod end. Stock and most aftermarket will require '71 and up outers. You will most likely need a special tie rod adjuster or the whole linkage from a '71 and up truck. |
Moderator
![]() Join Date: May 2007
Replace the whole thing. They will be much easier to adjust when you get the front end re-aligned. If you have the money, use Moog suspension parts.
Can actually order Moog thru Advanced Auto. Ledzepp, hoping the cash will let me get the Moog Parts but if not - I'm gonna buy the TRW Parts. They are also made in the USA and carry the same limited lifetime warranty as Moog.
BTW, there stock Spindles. Thanks guys for all the input.
