Old 11-25-2008, 05:53 PM   #1
rddaves54
rddaves54's Avatar
Ignition ring and cap
I was wondering how the Ignition Bezel Ring and the Ignition Bezel Spacer are to go together when the little cap keeps the ring from slipping over the ignition switch. Do you put the little cap on last? Do I take the cap off the ignition and then how does it go back on?
I have picture of ring and the little cap that came off old ignition.
Also I put a new steering wheel on and it was a little rusty I cleaned it with a wire brush and sandpaper that should be alright. I was wondering if that would make the horn not work if the connection is bad.
rddaves54 is offline   Reply With Quote
Old 11-25-2008, 06:02 PM   #2
john
member #16
john's Avatar
Re: Ignition ring and cap
That cover on the switch isn't supposed to come off. You remove the whole lock assy. There are directions in the FAQ section.
john is offline   Reply With Quote
Old 11-26-2008, 11:15 AM   #3
rddaves54
rddaves54's Avatar
FAQ section is that the search or what?
Old 11-26-2008, 11:23 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Go to the top of the page, click on Forums. Scroll down to FAQ.
Then you can do a search on the right hand side for Search this forum. I typed in ignition. You can use "lock", "key", etc...
http://67-72chevytrucks.com/vboard/s...light=ignition
68gmsee is offline   Reply With Quote
Old 11-26-2008, 03:04 PM   #5
john
member #16
john's Avatar
Oh I see you are a new member and can use a little help. Once in the FAQ section, there is a thread index which will have the FAQ's separated by engine, elec, etc. Here is one for ign switch removal. Hope this helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=123712
Old 11-26-2008, 03:09 PM   #6
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
sorry for hyjacking this thread but John, good to see there is someone local to me. iv just started my 67 build, i may have some questions in the future.-art
vasquezmrysvll is offline   Reply With Quote
Old 11-26-2008, 05:07 PM   #7
john
member #16
john's Avatar
Welcome aboard Art, Glad to help if I can.
