11-26-2008, 12:03 AM | #1 |
Gen III Question
If you install an LS- based motor, but you use a carb'd intake, what do you do for a fuel pump? Is there on on the motor?
On a side note, how much power can the stock gas tank support? Is it limited by anything? |
11-26-2008, 12:09 AM | #2 |
Re: Gen III Question
you would use an electric fuel pump (low psi pump)
Trueman |
11-26-2008, 12:10 AM | #3 |
Basically you run an electric fuel pump. They have fuel pumps that put out low pressure for carbs, I'd still run a regulator though.
They do make a front mount distributor set up that also allows you to run a distributor, but it's VERY spendy. |
11-26-2008, 12:24 AM | #4 |
Ok so it just needs an electric pump. Would that be in the tank or inline?
11-26-2008, 01:02 AM | #5 | |
I've never heard of a low pressure in-tank pump, but I could be mistaken.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
11-26-2008, 01:10 AM | #6 |
i have a aluminum tank under the bed...it does have pump inside..not to high pressure just stock 40-45 psi...i not its not the weakest but dont think its real strong...just needs to supply for my 350 tpi. i know i dont got the big daddy LS but just my lil bit of info
11-26-2008, 01:19 AM | #7 |
That is extremely too much pressure for a carb. It needs to be in the 5-7 psi range at best.
11-26-2008, 01:24 AM | #8 |
Ok so if I put a fuel tank under the bed, I just put a pickup in the tank and an inline pump outside?
11-26-2008, 01:35 AM | #9 |
Correct and as close to the tank as possible.
11-26-2008, 01:44 AM | #10 |
Alright sweet, thanks for the info. Im taking notes and making plans ;D
11-26-2008, 01:20 PM | #11 |
You could use an in-tank TBI pump. It has an output of 12-14 psi. You will still have to run a regulator to drop it to 4-7 psi.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
