Old 11-26-2008, 12:11 AM   #1
badriand
badriand's Avatar
Rear shocks?
Got 5 ich drop on back, you guys running drop shocks or has anyone found some stock ones that work fine? Right now , i am just using stock.
badriand is offline   Reply With Quote
Old 11-26-2008, 11:20 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Rear shocks?
How is your rearend lowered? Lowering blocks, shorter springs, etc? I set up my buddy's '66 (shorter springs and 1-inch blocks) with a set of OE-type Monroe oil-filled shocks that are normally for the front (since they are a little shorter).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-26-2008, 07:30 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Re: Rear shocks?
Igot a kit and it came with doestch tech's. I like them as they control rebound well.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-26-2008, 09:23 PM   #4
1restorick
1restorick's Avatar
Re: Rear shocks?
I lowered my truck 5" in the rear and used the KYB gas shocks from ECE along with the relocator brackets. Sorry I don't have a photo of the shocks only the truck. It rides super nice.
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 11-27-2008, 12:14 AM   #5
badriand
badriand's Avatar
Re: Rear shocks?
Where do the relocator brackets mount to? Got a c-notch on the back, with 5 inch drop coils.
Old 11-27-2008, 01:31 AM   #6
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Rear shocks?
I'm using a 4" spring with this shock relocator kit.
I've got the shocks all i know is they are KYB. I can try to find a part number if needed. I'm also running a Super track bar.
Alan's Classic is offline   Reply With Quote
