Old 11-28-2008, 01:40 AM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
Lets see your door panels
I am needing ideas for door panels in my 67 please post up what you have done with your METAL door panels!
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 11-28-2008, 02:18 AM   #2
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Re: Lets see your door panels
Here's mine.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 11-28-2008, 02:37 AM   #3
bigbadchev72
People know me
What is that material? did you do it yourself? how did you do them?
Old 11-28-2008, 03:04 AM   #4
Richard8971
I had my upholstery guy in Oregon do the door panels, but they are easy enough to do yourself.
The material is tweed. I love the way tweed looks and feels. I cannot guarantee all materials will mold the way tweed does so take caution if you decide to use a different material.
You simply get a piece of material large enough (leave an inch or so on each side for wrapping the material around the edge) to cover the panel and spray contact cement on the outside of the door and the inside of the material. Give it a chance to dry (as per cement instructions) and flip the panel and place (glue down) on top of the material (glue up) and press down hard to make the glue bond. (Try to keep the panel parallel with the grain of the tweed.) Spray a little contact cement on the back edges of the panel and the outside edge of the material. Give that a chance to dry and fold the edges of the material over the edge and adhere it to the back. Trim and cut material as needed for a clean wrap.
Flip the panel over and start moulding the material into the grooves and contours. Ta dah! You're done.
Hope my instructions make sence.
D
Sherlock Holmes
Old 11-28-2008, 07:10 AM   #5
Andy4639
Old member
Andy4639's Avatar
These are what I did. I went and got the panel material and covered them myself. Nothing spectacular but it works for me.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-28-2008, 09:50 AM   #6
GMC Jim
GMC Jim's Avatar
These are pleated door panels sewed to a 1/4" foam backing... And the door pull/armrest is from a 1970 Monte Carlo...........Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 11-28-2008, 10:29 AM   #7
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Here are my original panels.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-28-2008, 11:58 AM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
richard, it looks like the pannel wouldnt go back into the hole cut out in the door wtih carpet over it..im strongly considering doing mine somewhat like yours.....
John
1999 Toyota Tacoma 4x4
Old 12-04-2008, 09:12 PM   #9
Richard8971
Well, tweed is not very thick. It lays inside the grove ok. And just in case you were wondering, my truck must have been pretty bone stock when it was made. It did not come with any inside armrests!
Don
Sherlock Holmes
Old 11-28-2008, 01:00 PM   #10
Mudder
Mudder's Avatar
You can buy these from Classic Parts or LMC. The Venders here can probably get them also.
Mudder is offline   Reply With Quote
Old 12-04-2008, 09:08 PM   #11
bigsnookmaster
bigsnookmaster's Avatar
Here's mine, they're kind of a hybrid.70 panels with 72 armrests with wooden insert,covered in black Ultra-leather
bigsnookmaster is offline   Reply With Quote
