Old 12-01-2008, 01:25 AM   #1
tdave00
Restoring a 68 SWB
tdave00's Avatar
Will a 700r4 require new driveshaft?
My 68 has a powerglide in it now, but I want to swap for an overdrive tranny. Will going to a 700r4 change the driveshaft length?
tdave00 is offline   Reply With Quote
Old 12-01-2008, 01:43 AM   #2
Scottshotrods
Re: Will a 700r4 require new driveshaft?
when you do the swap it will change the length.The overall
length of the 700-r4 is longer than the power glide.You
can take your driveshaft to a driveshaft shop and do a
cut and weld and blanace .I would buy a new one for the
truck if we were doing it for you in are shop.
Justin
Scotts hotrods
Scottshotrods is offline   Reply With Quote
Old 12-01-2008, 01:49 AM   #3
Musclerodz
Yes, 700r4 is quite a bit longer. Shaft will need shortened, not that expensive to have done.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 12-01-2008, 03:59 AM   #4
paisaloco67
I would recomend an aluminium driveline
paisaloco67 is offline   Reply With Quote
Old 12-01-2008, 09:03 AM   #5
stunna
Why is this better?
stunna is offline   Reply With Quote
Old 12-01-2008, 05:06 PM   #6
tdave00
Restoring a 68 SWB
tdave00's Avatar
Originally Posted by stunna View Post
Why is this better?
I wasn't gonna say anything unless he offered to pay for it .
Old 12-01-2008, 04:22 AM   #7
tdave00
Restoring a 68 SWB
tdave00's Avatar
Thanks guys. Is a 200r4 the same length as the powerglide?
Old 12-01-2008, 05:10 AM   #8
67shortie
Green club
67shortie's Avatar
You have a shortbed, go to your local wrecking yard and pull a driveshaft out of a 90ish shortbed Chevy truck with the auto trans. This will be right on for your swap. I did this, bolted right in, yolk too.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 12-01-2008, 07:49 AM   #9
cdowns
cdowns's Avatar
no powerglide isshorter
Old 12-01-2008, 08:07 AM   #10
KrazyKevin
What have I gotten into
KrazyKevin's Avatar
What 67shortie said. I was just reading up on this same issue and ran across a thread where a board member suggested that if you have a shortbed, find a 90's model swb with an auto tranny at the junkyard and the drive shaft will work.
KrazyKevin is offline   Reply With Quote
Old 12-01-2008, 08:31 AM   #11
tdave00
Restoring a 68 SWB
tdave00's Avatar
Thanks again guys. I assume that an auto tranny in a 90's model SWB truck will be a 700r4/4L60?
