12-02-2008, 04:30 PM | #1 |
Dome light pin switch placement?
I am adding options to a customer's very basic '68 GMC truck and I have questions about the placement of the door jamb pin switches and about how all of these plug together at the fusebox. I am using the AAW underdash courtesy light harness, cargo light harness, and dome light harness.
Does anybody have pics of their install similar to this or a factory setup? Pics at the fusebox would be great also.
Don't tell me what you're gonna do...SHOW me what you've DONE!!! Click here for the TRUTH... Last edited by clean cut creations; 12-02-2008 at 04:32 PM. |
12-02-2008, 05:16 PM | #2 |
Re: Dome light pin switch placement?
"placement of the door jamb pin switches"
subscribed, I need to know this as well. |
12-02-2008, 06:47 PM | #3 |
'71 chevy s.bed/s.side
Not a real good pic, but hope it helps.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
12-02-2008, 06:54 PM | #4 |
The wires should have plugs that serve as jumpers and should plug directly into each other. There is a pigtail that comes out of the fuse block and the dome light plugs into this, followed by the courtesy light into the jumper wire ad the cargo light then plugs into the jumper on the courtesy lights, so the cargo light luminates when its switch is on and the dome light is activated or the door is open. The plugs are straight forward if this is a stock type harness. Hope this helps, Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-02-2008, 07:12 PM | #5 |
its all about the +6 inches
the only trouble is, there is no raised pad in the 67/68 truck door jamb for the switch.
12-02-2008, 11:06 PM | #6 | |
Don't tell me what you're gonna do...SHOW me what you've DONE!!! Click here for the TRUTH... |
12-03-2008, 12:07 AM | #7 |
Sisyphus was my mentor!
I've been thinking about the lack of raised pad on my 67's for the switch. I was thinking about brazing a nut onto the pillar somewhere between the hinges & threading the switch in there.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
