Old 12-03-2008, 01:47 AM   #1
thebox
thebox's Avatar
283 swap to 396
I have a buddy who wants to trade me a 396 with a 4 speed muncie for my 283 with a th350. Truck would for sure not be a daily driver after that but it sure would be fun to drive when i did. Any opinions on the 396 and would my 10 bolt be able to handle it?
thebox is offline   Reply With Quote
Old 12-03-2008, 11:15 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: 283 swap to 396
http://67-72chevytrucks.com/vboard/s...d.php?t=259536 This is what I did when I put my BB in. You don't have to go to this extreme but you might have to change out the perches to get some headers or even the stock headers to clear the engine perches. Some just use later model mounts and cut the frame back a bit.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is online now   Reply With Quote
Old 12-04-2008, 03:03 AM   #3
thebox
thebox's Avatar
Re: 283 swap to 396
That is great man thanks. How did you work your motor mounts? Did you use mounts and brackets from the bb or would you be able to sb mounts?
Old 12-04-2008, 10:55 AM   #4
Chevy Fleetside
Re: 283 swap to 396
The mounts are the same it is the perches that are the problem most of the time. You can't get a header on the left side without butchering the perch. I don't even think stock manifolds will work unless you cut the frame rail. The perches I have are aftermarket and cost about $140. They come with a car style motor mount.
Old 12-04-2008, 11:33 AM   #5
thebox
thebox's Avatar
Re: 283 swap to 396
Where did you buy the perches from? Really starting to hope this all comes together it will be a lot of fun stepping up from my 283!
Old 12-04-2008, 12:43 PM   #6
502tripower
502tripower's Avatar
Re: 283 swap to 396
It is much easier to use the 73-87 perches and mounts. Then buy headers for the same year.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 12-04-2008, 07:45 PM   #7
steverino66
Re: 283 swap to 396
what 502 said-
I went at it bassackwards getting 70-model big block headers, then had to find the right perches to get clearance on the driver's side; they're available aftermarket but pricey, if you're not in a hurry, watch the parts side of the site or craigslist for a deal. Good luck!
steverino66 is offline   Reply With Quote
Old 12-05-2008, 12:15 AM   #8
protrash64
Resistance is Futile
protrash64's Avatar
Re: 283 swap to 396
I got everything together to do this swap and didnt do it. Anyway, I found the perches 502 has for 20 bucks out of a 88 suburban. They were held on w/ jamb nuts, so warm up your wrists before removing!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
