Old 12-06-2008, 01:00 AM   #1
dubdeuce80
dubdeuce80's Avatar
need a measurement...
how much room is there from the back of the frame, to the end of the bed floor?
i'm gonna be doing a back half, but the bed i had was rusted out so there was no way to get a measurement...i don't wanna make the frame too long lol
dubdeuce80 is offline   Reply With Quote
Old 12-06-2008, 06:41 PM   #2
dubdeuce80
dubdeuce80's Avatar
Re: need a measurement...
bumpity bump plz
Old 12-06-2008, 06:47 PM   #3
67arch
WTB:Patience and Talent
67arch's Avatar
I'll try to get one tonight for you.
69 shortwide
67arch is offline   Reply With Quote
Old 12-06-2008, 08:42 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Looks like 3 3/4".... hard to be exact, I can't get the tape perfectly straight b/c there's a piece of metal side-to-side behind the ends of the frame rails.
edit: That's on my '72 LWB... you didn't say which truck, if it makes a difference
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 12-06-2008, 09:05 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have the bed off my truck right now do you just need from the last bolt hole or from the cab wall to the frame end?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-07-2008, 12:20 PM   #6
67arch
67arch's Avatar
I got 4" from the end of bed floor to end of frame rail. The bed support bolts to the very end of the frame so looks like a little longer frame ok but a little shorter and you'll end up fabbing some mounts. Hope this helps. If you need pics I can get some.
on a 67 long
69 shortwide
Old 12-07-2008, 01:18 PM   #7
dubdeuce80
dubdeuce80's Avatar
on a 67 long
cool thanks, sounds like i have between 3-4" of play then. 67arch, when you get a chance can you snap some pics? no real rush as i have quite a few other things on the to do list...
i needed from where the frame ends, to where the bed floor ends, but stocker and 67 got it taken care of...thanks though!
Old 12-09-2008, 10:08 PM   #8
67arch
67arch's Avatar
Here's some pics for you. Hope they help, let me know if you need something else.
69 shortwide
Old 12-09-2008, 10:19 PM   #9
dubdeuce80
dubdeuce80's Avatar
that works perfect, thanks man. i just wanted to make sure i had a few more inches in the back, since the gas tank i have is slightly bigger than the stock frame allows
