Old 12-07-2008, 12:01 PM   #1
69-72
69-72's Avatar
31x10.5 tire air pressure
What should I run them at?
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 12-07-2008, 12:08 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 31x10.5 tire air pressure
What does it say on the tires? I'd guess somewhere between 35-40psi.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-07-2008, 01:00 PM   #3
69-72
69-72's Avatar
What is says on the tires is the max pressure you can run them at. I am looking to see what Blazer owners usually do for this tire.
Old 12-07-2008, 01:16 PM   #4
bouncytruck
SKINNY TIRES RULE!
My tires say max pressure is 80psi (235/85r16) but I run them at 40. 80ps i makes a rough ride, 35 seems a bit soft. I confirmed with 2 tire stores and both said 40 is good.
bouncytruck 1972 K5
Old 12-08-2008, 12:35 AM   #5
stomper
Junior Member
stomper's Avatar
Air pressure in the tires makes a big difference in the ride for me. I run 'em around 32 unless I'm going for better mileage (ha!) then I run closer to 40 (max on my BFG's if I recall correctly) Ditching the stiff shocks for something softer would probably help my ride too.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 12-08-2008, 01:02 AM   #6
bouncytruck
SKINNY TIRES RULE!
What size BFG's are you running? Mine are BFG's too, but they are "E" load rating (the only rating for the size of tires.)
bouncytruck 1972 K5
Old 12-08-2008, 07:38 AM   #7
vtblazer
vtblazer's Avatar
Whatever it takes to get even tire wear.
Too much pressure and you'll clean the centers right off,. too little wears the outside and will handle like poo.
Read your side walls and start with the manufacturers recommended #s.
vtblazer is offline   Reply With Quote
Old 12-13-2008, 04:05 AM   #8
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Exactly, every different tire and rim package will be a a little different on what pressure wears the best. In my experience most tires like around 32-38 psi. Generally, I inflate the tires on cars that I work on to the max setting as most people don't check their air pressure. At Les Schwab we set at 35 psi on most tires for maximum tread life, unless rated higher such as a load range D or E. Thats what they told me anyways. but on the other hand when I started as a mechanic at the Ford/Lincoln/Mercury dealer we set psi by the model. Crown Vic got 35, and the Lincoln's town car were factory recommended as low as 28 psi for a nice cushy ride. it's all personal preference really. I run my 72 blazer at 32 psi on it's 33x10.50x15, my 67 gto radial t/a's 235/60/15 at 35psi, and my 1979 ford f250 at 70psi on 235/85/16 load range E's.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 12-13-2008, 12:38 AM   #9
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I don't have a lot of miles on my 31x10.50s BFGs, but I'm running 32psi front and 28psi rear. This is also what I ran in my old 30x9.50 BFGs with good results.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 12-13-2008, 10:58 AM   #10
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Over the last 24 years I've found that my K-5 handels and rides best with 45 in the front and 35 in the back. I have lowered it to 40 front and 30 rear, but found myself not liking how it cornered. I figured since most of the weight was up front the tires needed more up there. I currently run 235/75r16 coopper AWT's Load range E. The ride is fine at that pressure because of the sidewall strength. Having the "E" range I can then pack the rear tires to 50-60 (or more) for pulling a trailer, eliminating any sway.
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
