Old 12-07-2008, 11:05 PM   #1
srsummers
Removing the dash in a 65
How difficult is it to remove the Dashboard in a 65. My parts truck has a nicer dash than my project truck. Does it unbolt or do you have to cut it out? Has anyone every done this before?
srsummers is offline   Reply With Quote
Old 12-07-2008, 11:08 PM   #2
61hawk
61hawk's Avatar
Re: Removing the dash in a 65
It can be done, about 8 gazillion spot welds to drill out though.
61hawk is offline   Reply With Quote
Old 12-07-2008, 11:11 PM   #3
1966gmc
Why does it taste purple?
1966gmc's Avatar
Are you kidding? I have had my 66 for over a year and have really never took a good look at how the dash is in there. Dang it
1966gmc is offline   Reply With Quote
Old 12-07-2008, 11:35 PM   #4
shortbed70
shortbed70's Avatar
I was going to do the same thing only to shave everything but you have to remove the windshield and then there are sevral spot welds along the outter pinc weld. Do a search and there are a few builds on here that have removed them.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-08-2008, 12:09 AM   #5
Rogue
Airport Bum
It's not that bad.
I have done several, I have one dash hanging in the shop.
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 12-08-2008, 12:10 AM   #6
the kid
the kid's Avatar
i took one off a 65. it takes sometime u have to pull the windshield and drill all the spots out there all around 2" on center then un bolt it from the bottom.
making trucks pointless 1 at a time
the kid is offline   Reply With Quote
Old 12-08-2008, 12:33 AM   #7
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Like others have said remove windshield. There are spot welds on that pinch weld and bolts on the sides and to steering column/brake pedal support.
Alan's Classic is offline   Reply With Quote
Old 12-09-2008, 12:52 AM   #8
Tomsriv
Tomsriv's Avatar
So you cut the spot welds to get it out. But I have to ask, how do you put it back? Weld it back in?
I worked around my dash when I did my interior, once you pull everything out you can reach back there pretty easily to clean and plumb stuff, etc.
'65 Chevy shortbed stepside.
Tomsriv is offline   Reply With Quote
Old 12-09-2008, 12:57 AM   #9
Alan's Classic
Yes
Old 12-10-2008, 12:13 AM   #10
srsummers
Thanks for all of the input guys. I will definatly try in first in the parts truck. Any advice on taking the crack windsheild out of the parts truck? I will have my good windshield professionally removed and later installed.
Old 12-10-2008, 12:40 AM   #11
joe231
joe231's Avatar
it's already cracked, so just go for it
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-10-2008, 10:04 AM   #12
joe231
joe231's Avatar
we just removed the windshield from the '66. we started at an upper corner on the inside and pulled the rubber back and pushed out on the windshield, just work slow and use constant pressure ,should come out fairly easy....
CHEVY ONLY
Old 12-10-2008, 11:32 AM   #13
Rogue
Airport Bum
Just cut the gasket.
1964 Chevrolet C-10
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Old 12-10-2008, 11:51 PM   #14
Captainfab
60-66 Nut
If you want to save the windshield, just go ahead and cut the gasket....they're only $40-50.00. Besides it wouldn't hurt to have a new one when installing the windshield.
