Am in the process of having front,rear weatherstrip redone again. In eliminating soures of water seepage how do I distinguish between water entering from the weatherstrip or trickling through the body from the drip rails. What areas need to be filled with seamsealer to keep interior of truck warm and dry?
68 chevelle(garage queen) 72 cheyenne super(driver) Owasso, Oklahoma |
![]() Join Date: Apr 2000
There are 2 seams under the cowel. One is where your left foot would be and there is one on the pas side same place and the seam all the way across between the two. Check them.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
would the same seam sealer be appropriate here also and what is the best way to work the sealer itself?
CCRider
I have had several of these trucks and every time I have had a leak in the cab it was the drip rails. Just a small crack in the cauking can let in a lot of water. My 71 would pour inside and it looked like it was coming from the windshield weaterstrip but it was the drip rails. My 72 i have now, I resealed the drip rail when I painted it and I have all aftermarket weaterstripping installed with only soapy water to lube it. No sealer at all. And no leaks. Unless you have rust on the part of the cab that the weatherstrip seals on, sealer should not be needed. Inspect the driprails and suspect the smallest crack. GOOD LUCK
------------------ 72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
thanks...
Just an idea..Get inside the cab and have some one with a water hose on a trickle go over the entire area a small section at a time to look for possible leaky spots...
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
You could get a spray bottle with soapy water in it and turn on the heater blower on high and spray in small areas this will find small leaks that plain water might not show. Make sure the doors and windows are shut. Might even tape up obvious rust holes such as cab corners etc. If so applicable.
------------------ Current Project(s) 67 Chevy LWB (almost a truck again) 68 Suburban (Basket case ,got basket and its gettin fuller) DAILY DRIVERS 71 C-20 Built 327,4spd,4.11 Posi 84 K5 Blazer(Sorry this ride is closed for repairs) HiPerf cat., Flowmaster 94 GMC Conversion van (Wifes ride) Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" unknown
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80 Nice ride 67 Chevy C-10 LWB Built 350 TH-400 Wifes ride and family rig: 2001 Furd Expedition 5.4 Liter ![]() Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" Mark Twain |
