how do i put gas tank inside bed
hey guys im considering moving my gas tank into my bed i need to know what all i need etc. and if possible pics of someone that has done this before.
Re: how do i put gas tank inside bed
it seems like alot of work and im on a low budget so any info on how to do it in the bed?
Resident of Here
No info. Under the bed doesn't require a lot of money. Just tools and a few hours.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Is the gas the tank is holding for your truck engine or are we talking like an aux. tank for farm equip, race cars, extra gas incase you run out? If it is your primary tank be ready to cut your bed up to run lines to your engine.
You using a stock tank? Electric push pump or mechanical?
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
![]() Join Date: Jul 2001
Just my opinion but think you would be much happier with moving the tank under the bed. Besides the cost of the kit (tank, sending unit and straps) I doubt I have much more than $50 in cost. I purchased a poly tank from GMC Paul (excellant customer service by the way) and used junk yard parts to complete the install. I have a LWB 4x4 and it did require "notching" a floor support rib, installed the filler thru the driver's side wheel well in the bed. Works great and fills with no back flow. Give it some thought. Really like my under bed tank.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
