Between the earth and the sky
Thinking of changing from a 4 speed to an automatic...
But something tells me it's not as straight forward as I may think. Of course I need a tranny and torque converter, but I think I may also need a drive shaft. I have a regular everyday all american SB 350. I currently have a 4 speed saginaw tranny. I will also have a little issue with my interior since it's built all around my shifter:
![]() ![]() Has anyone done this change? I'd appreciate being pointed in the right direction. Thanks!
Chris - 1966 C10 Shortbed Fleetside, 1991 GMC Sierra 1500 Extended Cab, 1993 Blazer Sport 4x4 My other rides: 1969 Chevrolet Impala SS427 Convertible 1976 Dodge Tradesman B200 2002 Nissan Maxima 6 speed 2004 Mercedes Benz CL500 |
![]() Join Date: Sep 2003
Re: Thinking of changing from a 4 speed to an automatic...
blew clutch in my 65 c10 3sp moved to floor. rebuilt my first auto a th400 for it. 1200 mile break deer hunting trip worked great. You'll need trans,flex plate,dip stick, shifter (I traded used B/M ) probably need to rework /shorten or new drive shaft, new ujoints, oil cooler, lines, & crossmember. My shifter is cable controlled & looks like it could fit into or real close to console you have. Normally I'm a floor shifter guy but old lady's going to be driving this alot as I'm building a 54 chev truk right now. Got munchie m21 ripped off, so I'm going with 350 deal on that one for now. Local shops around here will build strong 350 or 400 for 5-$600 with shift kit. I was able to work off/trade labor for all parts & use of someone's tools so I was in mine for less then $100, but I had rebuildable 400 here. It is comfortable be lazy without shifting especially in traffic tho. Getting old i hate to admit. UR truck looks tits tho.
good luk JW Last edited by jwart; 12-15-2008 at 05:37 PM. Reason: grammar correction |
Hey if u make the swap and want to sell all the 4 spd stuff...id be interested, haha....good luck with the swap if u do it....
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
keep the console and go with a quarter stick (cable linkage) www.***************** can make u the crossmember u need for the auto that will bolt in good luck
making trucks pointless 1 at a time |
