Old 12-14-2008, 01:32 PM   #1
junkman1jmc
junkman1jmc's Avatar
camaro sub frame?????????????
i've heard some people say it's to wide for a 48 gmc but some people said that they will fit. tell me what you think? i can get a late 70's camaro frame just wanna make sure before i get it that it will work.
junkman1jmc is offline   Reply With Quote
Old 12-14-2008, 01:36 PM   #2
Cyclone
Cyclone's Avatar
Re: camaro sub frame?????????????
Yep too wide, use an S-10 frame.
Info here:
Cyclone is offline   Reply With Quote
Old 12-14-2008, 02:41 PM   #3
mr48chev
mr48chev's Avatar
The first series rear steering Camaro or Nova stubs work better than the later ones.
There is quite a bit of work to get the trucks frame rails to match up with the subframe although I know of a couple that have the complete subframe scabbed to the bottom of the trucks frame rails. Those aren't pretty but they work.
If you position it right you can bolt the stock core support to the crossmember that the sway bar on the stub fastens to with just a thin spacer On mine I drilled two holes. cut some spacers out of a sidewall of an old tire and used that for a mount.
The big rub with the rear steering box is that the column is the pits to get aligned decently. If I were to do it again I think I would use one of the columns out of a front wheel drive car that had the universal joints under the dash to get the wheel in the correct position and have the shaft match up with the box.
I ran 14x7 alloy wheels with 195-14 tires with this setup with plenty of clearance.
This photo was taken on the first trip with the subframe under the truck. 6000 miles in three weeks on a truck that had 100 miles on the redo before the trip started.
The photo was taken in 1981 in front of my mother-in-laws house in Texas.
I'd look into a GM metric front stub 78/80 something Chevelle, Cutlass or Regal for the stub swap. It uses the same suspension pieces as the S-10 and I believe that the track is the correct width and you don't have to use the wheel spacers.
Old 12-14-2008, 02:51 PM   #4
drummin89
drummin89's Avatar
there is always this option
http://www.stovebolt.com/ubbthreads/...338344&fpart=1
page 5 has links to pictures
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Old 12-14-2008, 03:49 PM   #5
Kid
Kid's Avatar
As Mr48chev stated, If your fab skills are up to par, then a front clip from a GM "G" body 78 to 88 grand prix, monte, malibu does have the correct width & wont pose steering column issues. Remounting the front sheet metal & radiator to the new clip is the most difficult part, but very doable, & will drive like a dream.
Kid is offline   Reply With Quote
Old 12-15-2008, 02:45 PM   #6
nebdrummer
nebdrummer's Avatar
1977 and prior elcamino works grand.
nebdrummer is offline   Reply With Quote
Old 12-15-2008, 04:16 PM   #7
Houston54
You could have found lots written on this subject but doing a simple search. But since you did not here is my $0.02.
The G-body subframe does have the correct track width but it is not an easy modification as the steering box interfers with the radiator core support. This requires extensive modification to clear the box and the radiator bottom has to be kicked forward to clear it. If you can fabricate then you can do it but it is not simple.
The S10 is not as easy as some would make you think nor is it less expensive than a IFS kit.
If you must do a subframe the rear steer GM subs are the best option for the AD truck series but the best solution is a IFS kit. It is your truck though so have fun.
Houston54 is offline   Reply With Quote
Old 12-15-2008, 05:21 PM   #8
youngrodder
youngrodder's Avatar
My truck uses a G-body frame. It was set up by the PO. I agree with your comment about the steering box. It came with a 46-48 chevy car radiator and it sticks up too high for my liking. To comlicate matters, I changed to a LT1 (reverse cooling) and I have found a 3 core radiator for a 32 ford that I might try. This wil allow me to offset it to clear the steering box.
I have air bags and plan on running 20" wheels up front and I do like the track width.
Marc
youngrodder is offline   Reply With Quote
Old 12-15-2008, 10:20 PM   #9
bighaas79
anyone have any pictures of a frame done with a 70's camaro sub grafted in? I was planning on going this way too on a 54 gmc and was curious to see how they turned out.
bighaas79 is offline   Reply With Quote
Old 12-15-2008, 10:25 PM   #10
JML55
JML55's Avatar
Check this thread it shows it being done on a 58 chevy.
http://www.jalopyjournal.com/forum/s...d.php?t=148978
JML55 is offline   Reply With Quote
Old 12-17-2008, 08:50 PM   #11
55dude
55dude's Avatar
gm a-body 78-88 have the correct track width and you could use s-10 rear frame half. front suspension is same as s-10.
55dude is offline   Reply With Quote
Old 12-17-2008, 08:52 PM   #12
nebdrummer
nebdrummer's Avatar
do you have any shots of this subframe 55dude? i'd like to see that one.
Old 12-17-2008, 11:13 PM   #13
mag-d
Name:  truck pics 001.jpg
Name:  truck pics 003.jpg
Name:  truck pics 002.jpg
Name:  truck pics 013.jpg
Name:  truck pics 008.jpg
Here are some pics of my camaro sub install on my 50
mag-d is offline   Reply With Quote
Old 12-17-2008, 11:32 PM   #14
nebdrummer
nebdrummer's Avatar
blower in the plans?!!! :biggrin:
Old 12-18-2008, 10:11 AM   #15
bensimmons_05
bensimmons_05's Avatar
If you look at that picture just right it looks like the truck on the right is normal size and it looks like the one in the foreground is 3x its normal size and sitting on the ground..... just thought it was funny
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 12-18-2008, 10:33 PM   #16
bighaas79
mag-d where in iowa are you at? If your close id love to come check it out if possible.
Old 12-18-2008, 11:04 PM   #17
watahyahknow
watahyahknow's Avatar
i've seen a couple of people putting the sheetmetal on the S10 frame as a whole and just drive it that way .
from wat i understand the track and the wheelbase is pretty mush the same and you only need to make bodymounts
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
