12-15-2008, 05:43 PM | #1 |
Radiator Help.....AGAIN!
Ok I'm enlisting everyone's help again. So I've had a time trying to get a new radiator in my truck. I switched from the 2 to 4 core, bought new retainers and pads, go everything hooked up and realized that there was no place on the radiator for the heater hose. I contacted RockAuto (where I bought the radiator) and they contacted Spectra Premium (the company who made the radiator) and they said that the radiators are not built with an outlet for the heater hose and it has to be rerouted. The kicker is that the guy from Spectra Premium didn’t know how to reroute it. He said it makes the heat more efficient, but was no other help.
Anybody know how and where to reroute the heater hose? Thanks in advance!
Camouflage 1971 Chevrolet C/20 2WD |
12-15-2008, 05:48 PM | #2 |
Between Trucks...
Re: Radiator Help.....AGAIN!
Reroute from the water pump and intake manifold. It's raining here, maybe later I'll be able to get out and take a look at the exact routing.
Beat it to fit, Paint it to match... |
12-15-2008, 05:56 PM | #3 |
Between Trucks...
Went out and checked. Water pump to upper fitting at firewall, intake manifold to lower. I have factory air though so it might be a different deal with just heat.
12-15-2008, 05:57 PM | #4 |
Watch out for your cornhole !
There will be a plug on the passenger side of your water pump, just above the radiator hose. It is 1/2" NPT. You will need a bib that screws in place of that plug appropriate to your heater hose size.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 12-15-2008 at 05:58 PM. |
12-15-2008, 06:02 PM | #5 |
It may be asking a lot.....but can anyone take a picture of what it looks like?
12-15-2008, 06:22 PM | #6 |
He is a picture of my 350 in my step. I circled the plug in blue. Just unscrew the plug and screw a fitting into place.
12-15-2008, 06:34 PM | #7 |
Thanks that helps a lot! One other thing....what advantage does that have over being connected to the radiator?
Camouflage 1971 Chevrolet C/20 2WD Last edited by MBurns326; 12-15-2008 at 06:35 PM. |
12-15-2008, 06:54 PM | #8 |
nothing better about it. heere is how mine is hooked up
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 12-15-2008 at 06:56 PM. |
12-15-2008, 07:23 PM | #9 |
It gives faster heater warm up due to the heater core water returning to the engine rather than the radiator. The theory is that the heater water basically stays in the engine and heater core rather than involving the radiator until the engine warms enough to open the thermostat.
