12-16-2008, 06:10 PM | #1 |
need help with wheels.
I know I want 22's, and I like the deep dish look. What are you guys running for a 22in wheel, and what bs do I need. Its a '67 sw, but I'm not sure what rearend I have, whats the measurements on the 2 sizes?
12-17-2008, 11:51 PM | #2 |
Happy to be here
Re: need help with wheels.
Anyone?
12-18-2008, 10:21 AM | #3 |
A guy with a truck
You are trying to lay frame on this truck, correct? 67-70 rears are 1.5" narrower than the later rears. BS will be dermined depending on wheel width. Most 22s I see are 9-9.5" wide, so with the early rear, you will want around 5" BS- late rear ~5.5". These are general guidelines- best thing to do is measure for your truck 'cause each one is slightly different.
-Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-18-2008, 10:31 AM | #4 | |
The Big Green..... The best guy I know to determine what wheel back-spacing belongs on your truck would be you.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-18-2008 at 10:32 AM. |
12-18-2008, 10:50 AM | #5 |
Thanks guys, thats all I needed. I do know that I need to be the one that measures. Being that most guys my order their wheels online got me worried. I would hate to get it wrong, and be screwed out a set of wheels. I'm trying to get them thru a wheel dealer here local, and if they are wrong, no biggy. The wider, deeper dish wheels seem hard to get at a shop local.
12-18-2008, 03:22 PM | #6 |
Tot Roddin'
IMO... find the most reputable shop in the area and use them. Not that the less reputable shops would be bad, but if they have ordered larger dia. wheels in the past with custom BS I would trust them far more than I would another shop with less experience.
Best of luck with the decision as the wheel/BS selection is one of the hardest in my opinion. And as always, be sure to post a ton of pics!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-19-2008, 12:56 PM | #7 | |
The shop I use, I have been dealing with for all my years of driving, all 12 of them. I am bagging first, because then I will know what fits best, when dropped. They have sold one set of 30's, would that look good?...lol Thanks for the help. I will try my best to use this shop, but some makes of wheels you can't even get thru them. |
12-19-2008, 01:27 PM | #8 |
Then use different ones that you can get from them. Use any resource you can to help get it right.
12-19-2008, 09:24 PM | #9 |
I've always measured my own BS, simply because I don't trust anyone else to do it. I like the deep dish look as well , make sure whoever does it knows how to measure it out to get the maximum dish.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
12-19-2008, 09:52 PM | #10 | |
SCOTI Theres not many places to choose from around here. I'll get wheels someday. Seems like I have been looking forever...lol. So many choices, and sizes. I remember when 15's where it, and if you wanted to be really cool, you got 15x10's...lol. Now there are 32's, I saw a Hummer on 30's a few months ago. The guy is a track runner, Wallace Spearman, or Tyson Gay owns it, I forget. Its awesome but huge. Anyways thanks guys. |
12-20-2008, 04:03 PM | #11 |
67-72 parts collector,…
Your suspension guy should be able to set up your bagged suspension without having the actual wheels. Just give him the overall tire height. Or get some cheap roller 15's (235/75-15's) that are close to the height you want.
edit: Should have said 15's.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-20-2008 at 07:30 PM. |
12-20-2008, 07:09 PM | #12 | |
I have the 275/60 on back and 235 on front that matches diameter on back, 70 I think. I can do a rally wheel but I'll be a little off for the front smaller tire. Last edited by The Big Green; 12-20-2008 at 07:10 PM. |
