headers with a 3spd
i've been searching the forum for this answer, and can't find it.
i have a 67 c10 swb fleetside, originally a 6cyl w/ a 3spd on the column, it is now a 327 and has been converted to a floor shift, i would like to install a magnaflow exhaust system and want to know what headers would work with the least modification, i would prefer long tube, but whatever works. someone here in town has a set of flowtechs that are supposed to fit this truck, but he doesn't know the model # i just found this forum today, and i haven't been able to stop reading it yet. i'll post pics of the truck as soon as i can. |
Chevy nut
Re: headers with a 3spd
I had a set of Hooker super comps on my 69...350 3 speed converted from column to floor
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
We had to modify the clutch bellcrank to clear the cheapee Summit headers.
I too have been searching to no avail. I even called Summit and they dont list any (longtubes) for a man. trans. truck. I have Blackjacks (old) on now and need some with large O.D. ...Looks like its Hammer time again.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
my 78 has a 350 with a 3 speed and flowtech longtube headers and they fit fine, its still column shift though.
i called jegs and they said the 30055 jegs long tube headers should fit with no major modification
![]() Join Date: Nov 2005
I used block huggers with out any issues... couldnt use longtubes because of ground clearance.
This is no help ,but the 70 we have had long tube headers .I don't know the brand cheap i'm sure . They fit great ,but the z bar fit in between the tubes .Had to remove it to remove headers on driver side .
#9 | |
any insight would be great. |
