Old 12-18-2008, 04:13 PM   #1
speed-racer
speed-racer's Avatar
why do my windshield wipers sqeak
My windshield wipers squeak sooooo bad. It is driving me nuts.....it sounds like its a bushing. I can spray some lubricant on the linkage and it stops for a little while. If it is a bushing where can I buy them?
speed-racer is offline   Reply With Quote
Old 12-18-2008, 05:08 PM   #2
cdowns
cdowns's Avatar
Re: why do my windshield wipers sqeak
have you sprayed real good the towers where the wiper arms attach to? a very good glass cleaning also helps,i use BONAMI (its safe on glass) to deep clean the glass
Old 12-18-2008, 05:23 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
Mine are squeaky too, but it's the mechanism under the dash that's making all the noise. Is that where you lubed it? Mine would also stay quiet for a little while, and then make noise again later. I guess I will replace it eventually.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-18-2008, 05:50 PM   #4
cdowns
cdowns's Avatar
with no lubrication to the towers it makes everything else work very hard //eliminate the excess resistance in the towers and lots of noises disappear
Old 12-18-2008, 06:28 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I agree with all above. The linkage to the wipers from the motor will need to be lubed. I'd suggest something like LPS 2 or LPS 3. Something that is heavy enough to last awhile. There shouldn't be anything under the dash, that I know of, that should be squeaking....unless the wiper motor bearing(s) is/are bad.
As for the windshield, here's my suggestion.
Before you begin, place a 0000 steel wool pad at the top of the windshield and let it go. Note how it slides down the glass. Then:
1. Clean the glass with window cleaner.
2. Get some 0000 steel wool and wipe/scrub the windshield glass.
3. Clean the glass again, with the window cleaner.
4. Wipe the windshield with Rain-X, then follow the instructions on wiping it off.
5. Apply a second coat of Rain-X.
Now, take another pad of 0000 steel wool and let it slide down the windshield.
See the difference?
Don't use steel wool any coarser than 0000 (4-ought) or you will scratch the glass. If you old windshield is already scratched up, this may not be a biggee, but this procedure, when done on new glass, will really help you on rainy days, etc.
Member Nr. 2770
Old 12-18-2008, 09:20 PM   #6
kamikazekyle05
kamikazekyle05's Avatar
Mine drives me nuts too! Im gonna try this
kamikazekyle05 is offline   Reply With Quote
