Old 12-18-2008, 10:07 PM   #1
into69z
"brand new second-hand"
into69z's Avatar
1969 big block fuel line size
I recently installed a 468 big block in my 69 c-20, and my question is is there a dirrerence in the size of big block fuel line from the tank to the pump vs a small block? I saw an ad that says 3/8 was the size for factory big block but I can't back it up. I also installed a new rearend from a 1986 3/4 ton truck that has a 3:23 gear. This is a 14 bolt but not the heavy duty (dana 70) type-anyone run this rearend with any problems? Thanks Steve
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 12-18-2008, 10:17 PM   #2
caminokid
Chevy nut
caminokid's Avatar
Re: 1969 big block fuel line size
Mine is a 3/8th line.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 12-19-2008, 12:48 AM   #3
71 super
71 super's Avatar
3/8 ths here as well, but I think that was common for all V8 trucks, while 6's got 5/16 lines
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-20-2008, 04:19 PM   #4
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
3/8s was original on 350 & BBs and should feed your engine fine...IF there are no restrictions. Check the fuel line from tank to carb to make sure there are no kinks or crimped spots. Look inside all your fittings, especially if any are non-stock. Some of these fittings & fuel blocks are too small inside. Check the fuel sock inside the tank, too.
PICKMUP is offline   Reply With Quote
Old 12-21-2008, 12:18 AM   #5
into69z
into69z's Avatar
thanks-never thought of the fuel sock in the tank..
Steve
67 Camaro
96 Impala ss-sold
b69:
