Old 12-20-2008, 12:30 PM   #1
littlee_domn8r
AKA "Hurricane Hank"
littlee_domn8r's Avatar
Heater took a crap
Hi all. Haven't been on here in a while but see alot of new people. I have an issue with my trucks heater. I went to turn the fan on the other day & sparks flew from under the dash. Needless to say, now it doesn't work. Am I going to have to replace my entire control unit? Anyone ever had this happen? Thanks in advance for any help you can give me.
"looking back, knowing that you gave it your all.... win or lose, you finish a Champion" Dale Earnhardt
"They say hard work never killed anyone, But why take a chance?
63 GMC C10 Custom LWB 355/350 AT
00 Chevy Silverado 1500 base V6/AT
07 Chevy Monte Carlo SS 5.3 V8
littlee_domn8r is offline   Reply With Quote
Old 12-20-2008, 01:24 PM   #2
LILRED66
LILRED66's Avatar
Re: Heater took a crap
If it was under the dash, it is probably the heating element on the backside of the heater box under the dash. It is attached to the backside of the box with two 1/4" screws and has a wiring harness plugged into it. I would check this item first, because it sounds like that may be your problem.
LILRED66 is offline   Reply With Quote
Old 12-20-2008, 02:11 PM   #3
jwart
i've got thrift heater - single knob control, could it be the resistor for the fan speed control. believe lilred is talkling about that part.
ClassicParts.com has part#68-375 for about $7. none of my local auto parts could even find listing for it anymore. Napa did have a blower motor for $20 on hand. i ended up temporarily running my fan on hi with toggle switch for awhile. does your heater normally heat ur cab enough for ur climate? 1st winter using mine as daily winter driver & been putting off replacing heater core-probably my weakspot getting enough heat.
merry xmas & stay warm jw
jwart is offline   Reply With Quote
Old 12-20-2008, 07:35 PM   #4
rickf
rickf's Avatar
Yeah... when LILRED wrote "heater element", I was thinking what? The "heater element" for these is the thing we call the heater core, heated by engine cooling water, in turn heating the air (but you know all that, I'm boring you).
On the other hand, what is a resistor but a little bit of wire that dissipates some voltage by turning it to heat?
So, everybody is right.
I agree the most likely thing is the fan speed resistor pack. WHen one of the coils goes it can sproing over and make a short, there's your sparks.
Anyone know what the values are for these resistors? If mine ever goes I was thinking of putting in some potentiometers (aka variable resistors) so I could "tune" my fan speeds.
I put in a fan motor on the spendy end awhile back (about $45, mainly hoping it had better bearings and so would outlast the $16 motor). I was surprised how strong it was compared to the old stocker. On high it is high, of course, but it draws more current than the original so on low and medium it hardly goes. So I need some slightly "smaller" resistors, or adjustable ones. But I don't know where to start, what range to look for.
rickf is offline   Reply With Quote
Old 12-23-2008, 12:36 AM   #5
littlee_domn8r
The sparks came from up where the controls are. I went out & messed with it this weekend. Put a new fuse in & it works. I couldn't see any visible burn marks, but I did notice that the 3rd lever (out of 4) seems to be broken & it wasn't before. It just flops around.
Old 12-24-2008, 02:25 AM   #6
Captainfab
60-66 Nut
It sounds to me like maybe your fan switch shorted out thru the lever somehow. You might want to pull the heater controls out and have a look. You should be able to get it out a little ways without disconnecting the cables
Old 12-24-2008, 02:37 PM   #7
LILRED66
LILRED66's Avatar
I am not talking about the heater core...I am talking about the heater element attached to the backside of the underdash plenum box. It is an electrical item with a coiled resistor in it that heats up to red hot when current is applied. It is not the heater coil that is in the underhood heater box.
Old 12-25-2008, 11:30 PM   #8
littlee_domn8r
I must be missing some parts. the heater element is just sitting there inside the box in an open hole in the box.
My heater has always kept the cab plenty warm. I don't drive it much in the winter anymore, but used to a few years back. I have the deluxe heater.
Thanks for all your help!
Old 12-26-2008, 03:33 AM   #9
joe231
joe231's Avatar
heater element
it is called a blower motor speed resistor. it is placed inside the heater box for cooling to extend the life of the resistors. depending on which wire is energized, via the blower motor switch, the speed of the fan changes, with no (or very little) resistance on high.
here is a pic and link
Blower resistor
rickf, you have a multi-meter? you could measure your stock resistor
if not, I will try to get you values in the next day or 2.
CHEVY ONLY
joe231 is offline   Reply With Quote
